<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtNodeId="630"><!-- / icon and title --><!-- message -->
anyone have any ideas how to quiet down a noisey front differential?
Way back in the olden days, car dealers/sellers used to put sawdust in the diff to make them quiet.......not recommended of course, just reminiscing...
pulled the front cover off and the spider gears look to have some play in them, not sure how much is normal or if this is even the source, the ring and pinion look good but I didn't check the backlash, oil was full and clean, no metal shavings
They get warm under normal use, especially front riffs that haven't broken in fully. During break in, my rear diff was too hot to touch at times, around 180f.
It can be possible to change the pinon bearing fairly easily. The carrier bearing shims are captured and its fairly easy to remove the carrier once you get the axle shafts out. The toughest part is the crush sleeve if you elect to do a new one. that is the ideal way to do it however, you can check the preload prior to removal (which will probably be pointless if the bearing is bad) and tighten up to the crush sleeve without over torquing it. You should check the final preload, I would guess with a new bearing it should be set to 20-30 inch lbs.
If you elect to do the inner bearing it will be a little more difficult as it needs to be pressed off. It may not be damaged however. Sometimes the outer pinion bearing doesn't get sufficient lube if the level drops but the rest are ok. It's also more susceptible to dirt contamination and there is less mass to keep it cool back there.
