Need advise on egr delete kit for 6.0 L - Ford Truck Enthusiasts Forums
Old 02-27-2012, 12:48 AM
FORD_F-350. FORD_F-350. is offline
FORD_F-350. is starting off with a positive reputation.
I've got a Ford 6.0 I need some advise, people say to put in a egr delete kit in a 6.0. How does that benefit the truck and how is that useful?
Old 02-27-2012, 07:07 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
There are lots of pros and cons to this subject. One thing to take in to account is if you have emissions testing in your area. If so then you do NOT want to delete your EGR cooler. You shouldn't delete the valve anyway, just for operating reasons.
Old 02-27-2012, 09:46 AM
eagleinms eagleinms is offline
eagleinms is starting off with a positive reputation.
Quote:
npccpartsman,
I am curious about the last sentence. I did a delete and took out the valve, could not see why to leave it. Should I stick it back a plug it up? Think I tossed it, should I get another, is it that important? What issues would/could it cause? The more I read the more I learn.
Thanks & God bless
Eagleinms
Old 02-27-2012, 10:05 AM
AJB201 AJB201 is offline
AJB201 is starting off with a positive reputation.
My truck was having EGR valve issues so I put a sinister EGR delete kit in it and it has been running great since. Looked back through the warranty issues to and they had replaced my valve 3 times and cooler 2 times so I figured just delete it and forget it. No problems since.
w_huisman's Avatar
w_huisman w_huisman is offline
w_huisman has a good reputation on FTE.w_huisman has a good reputation on FTE.
Removing/unplugging the valve has proven to negatively effect radiator fan operation.
Old 02-27-2012, 10:09 AM
Quote:
Originally Posted by eagleinms View Post
npccpartsman,
Thanks & God bless
Eagleinms
That's really more for the 05 and up guys. The 03/04 model trucks don't have fan issues from the EGR valve that the tuning guys have been able to find. I just recommend not getting rid of it if it's still there, even with an EGR cooler delete. If yours is gone and you're not having fan issues then don't study it.
Old 02-27-2012, 12:44 PM
CODE P0528=fan speed sensor circuit malfunction, does not seem to effect ECT though
Old 02-27-2012, 07:05 PM
Didn't you also have P0403 & 5 EGR codes which are on the same part of the harness as the fan???
Old 02-29-2012, 09:16 AM
Sorry about the delay in answer, work,work,work. Yes, have the 403&5 codes with the fan 528. Put new t-stat in 2-27, old 1 fell apart in my hand after removal. Not been able to drive yet. Hope this helps the EOT=ECT spread.
has my EGR been deleted? cocoabeach_steve 6.0L Power Stroke Diesel 11 04-11-2014 10:32 PM
Who makes the Best EGR Delete Kit? Whitey Ford 6.0L Power Stroke Diesel 20 03-02-2013 10:52 AM
How to tell if egr delete is on 6.0 Robby Nash 6.0L Power Stroke Diesel 12 12-07-2012 08:37 PM
EGR Delete Regulator1988 6.0L Power Stroke Diesel 16 05-28-2012 05:36 PM
Thoughts on egr delete kit GaSouthern250 6.0L Power Stroke Diesel 9 01-11-2012 07:01 PM
Tags
04, 2004, 60, 60l, adds, benefits, biodiesel, delete, egr, f250, ford, kit, programmer, put, putting, reviews
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
