Front Sway Bar Bushing Replacement (with pics) - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 10-31-2012, 08:16 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Originally Posted by 03-6L-X View Post
What are the torque specs for the endlinks and sway bar?
End links= 80 lb-ft.
Stabilizer bar bushing bracket bolts= 41 lb-ft.
  #47
Old 10-31-2012, 03:01 PM
03-6L-X's Avatar
03-6L-X 03-6L-X is offline
03-6L-X has a good reputation on FTE.03-6L-X has a good reputation on FTE.
Here is another place to order the Energy Suspension parts:
If you have bad endlinks now you can order just them.
Hope this helps.
Suspension Restoration Parts Co.
4.5180, 36mm
Sway bar frame bushing set only.
$17.00
The Ford endlink has a metal bearings in each end,
instead of rubber bushings.
You will have to have a machine shop
PRESS out the metal bearings
to install the new polyurethane bushings.
<SMALL><BIG>If you want to order just the</BIG></SMALL><SMALL>Endlink grommets & inner sleeves only
from the 4.5186,
request these part numbers:
4) 2592
4) 2593
4) 15.10.245.39
$28.00
</SMALL>
<SMALL>
</SMALL>
  #48
Old 10-31-2012, 04:12 PM
X-Hibition's Avatar
X-Hibition X-Hibition is offline
X-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to all
Now this information, not the poster, is only about thirty five years old, but, when I was selling parts in college the "G" suffix on the Energy Suspension part number meant it was black, not green, in color and graphite impregnated, hence the "G". Later on they added grease fittings as an option on sway bar bushing kits, not end links.
Happy Halloween from an old fossil.
  #49
Old 11-03-2012, 11:50 AM
03-6L-X's Avatar
All finished with the front, what a difference. Now I have a sports car again.
When you press the original bushings out, the big bang and the flying bushing makes you jump a little. Don't want to get hit.
Thank you again to rla2005 for the torque specs. Tight, tighter and max tight are not the safest specs when it comes to this .
  #50
Old 11-03-2012, 12:35 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Can the bushing be banged out using a 1 1/8" socket and a hammer ?
  #51
Old 11-03-2012, 02:31 PM
BroncoRN BroncoRN is offline
BroncoRN is starting off with a positive reputation.
Do 2wd trucks have front sway bar?
  #52
Old 11-03-2012, 02:47 PM
03-6L-X's Avatar
Quote:
You probably could, but it would be way to risky as you might end up destroying the endlink in the process. If you could "borrow" a press that is the way to go. Will take you 30 minutes.
  #53
Old 11-03-2012, 03:34 PM
My Dorman complete end links just arrived and I might do a write up on them.
  #54
Old 11-03-2012, 04:31 PM
gr8scott72 gr8scott72 is offline
gr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant future
I just got my Moog complete end links just a few days ago.
  #55
Old 11-03-2012, 05:37 PM
Well it sounds like when they are bad it's pretty noticeable. I climbed under the truck and mine is pretty solid. It squeaks a little side to side but not sloppy at all. Rubber where it mounts to frame is old and cracking. Would slop be noticeable by hand if they were bad?
  #56
Old 11-03-2012, 05:38 PM
rla2005's Avatar
Happy to help out!
  #57
Old 11-03-2012, 07:40 PM
Quote:
Probably not because you can't put anywhere near the force on it the truck does. I would go by the noise and the main bar mounts are cheap and easy to fix.
  #58
Old 11-08-2012, 04:10 PM
Diesel Newb Diesel Newb is offline
Diesel Newb is starting off with a positive reputation.
Is everything on my truck just different?!?
I FIGURED IT OUT!!! We're looking at the diameter of the sway bar, not the width of the shackles. However, I'm going to leave this in case somebody else has the same question...
Top is the 32mm bushing that's in the regular kit. Bottom is the bushing that's special for the X. It looks like I don't need the special ones. (The answer is use the special ones, it's the bar diameter not shackle width.)
  #59
Old 11-08-2012, 04:20 PM
Quote:
Originally Posted by Diesel Newb View Post
Top is the 32mm bushing that's in the regular kit. Bottom is the bushing that's special for the X. It looks like I don't need the special ones. Yes/no?
Those are for the middle part of the bar that attaches to the frame and either one would work. Those are very easy to put in especially with an impact wrench. I just bought 2 of those (blue) for $11.50 at O'riellys made by Moog. Mine are blue and harder than the stock ones. Update! My truck is very quiet now after replacing the end links and the main bar mounts.
  #60
Old 11-08-2012, 07:11 PM
Banks Torque Tube headers V-10 install w/pics WE3ZS Excursion - King of SUVs 125 02-20-2017 11:54 PM
Cool, Fridge Club KustomKidd 1957 - 1960 F100 & Larger F-Series Trucks 21 01-24-2015 09:33 PM
my ride. cheezit 6.0L Power Stroke Diesel 49 10-07-2014 01:40 AM
Fuel pump frustration, what do I have? WE3ZS Excursion - King of SUVs 58 04-09-2014 05:55 PM
48-52 Rear Cab Mount Rebuild bobbytnm 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 12-10-2012 11:35 PM
Tags
1999, 2003, bar, bushing, bushings, edge, f150, f250, f250sd, ford, greasable, link, replacement, superduty, sway
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
