1981 ford f100 question
But, I don't think it is in the length of the extension. You have a lot of adjustment in that link, and should be able to overcome too much extension. I'm guessing that it is the way you are attaching the linkage to the carb. You mentioned something about what the manual says. Did you connect it the way the manual said?
One thing I've seen, if you don't connect to the carb correctly, is the kickdown travel is much less then the throttle travel.
The kickdown linkage should only be pushed at the end of the throttle travel....meaning you should only be actuating the kickdown when the throttle is wide open. I've seen where the kidkdown is attacked to the wrong place (usually on a carb without the proper ford kickdown linkage) and is pushing the linkage as soon as you start stepping on the gas. At some point, the kickdown will run out of travel and the throttle is only partially open. One may think that the kickdown is binding but in reality it's gone as far as it's supposed to.
I can't tell from the picture if it's connected to the proper linkage on the carb...or if the proper linkage is even there.
Like Gary says...disconnect the linkage and see if it travels smothly. If you have a second set of eyes, have someone look at the linkage at the tranny while you do this. You should see the linkage on the tranny travel counter-clockwise about 45 degrees.
81 F100 - 302 - AOD here and I have the tube linkage (to the tranny). That setup is confirmed in my OEM shop manual as well. Or did I misread the cable/tube part to be regarding the tranny link when you guys meant the throttle?
I think you read it correctly, we were talking about the transmission's kick-down linkage. But, I'd forgotten that some (early?) AOD's had a link like the C6.
You need to positively ID what trans you have. My 1981 F100 came stock with a 302
and an AOD trans. The TV control rod looks exactly like yours does. If that rod is not
hooked up properly and calibrated to the throttle movement on an AOD you will destroy
the transmission very quickly. If you have a C4 then just get a Holley kit to hookup the
kickdown for the C4. Look at the data plate on the driver's door and post the trans
number. Someone here can decipher it for you.
