Leaking up pipes
on
1 Post
Leaking up pipes
I have an idea for my up pipes that have been leaking. The left side is good, but the right side had been leaking for a while apparently cause it washed groves out of the end of the pipe. My idea is to come down about 3" from the end of the pipe where it goes in the collector and cut it with a pipe cutter to make sure I get a straight cut. Then flip that 3" piece around and tig weld the bad end back to the pipe so I'll have a nice smooth end going back into the collector. Do you guys think that will work??
Also I have read that some guys take thier pipes to a muffler shop and have the ends slightly expanded to make the new Ford donut gaskets ( which is what I have ) fit a little tighter. Do you think that's necessary ??
Riffraff Diesel Performance Parts: - International Bellowed Up-pipes
With shipping/tax I imagine so...
Google Image Result for http://www.cosconline.com/9912_Exhaust_Flexible_Pipe.jpg
on
1 Post
Just wondering if something like this would work to make your own flexible up pipes?
