351w power estimate
351w power estimate
just curious if yall might be able to guess how much power my engine makes after my upgrades since i cant afford a dino test yet. It's an 84 model block with the folowing:
elderbrock performar intake
summit cam Duration 262/272, Lift .448/.472
pace setter shorty headers
holley 600 4bbl
E7 heads with the thermactor humps ground out
MSD street fire box with accel super stock coil, plugs gaped at .045
timing gear set
thanks
holley 600 4bbl
timing gear set
thanks
On a slightly different slant, can someone confirm the claim by TFS for their top end kit for the 302? Their kit of intake, heads, cam, and rockers advertised in Summit shows 350 or 360 HP, depending on which kit you get. I estimated that the stock 19 lb injectors are only good for about 300 hp, but they don't address that at all. Are they overselling? (at ~$2500 for the kit)
screaminford
04-20-2012 04:12 PM
earlybroncoboy
06-14-2007 09:59 PM
