C6 Transmission vacuum modulator - Ford Truck Enthusiasts Forums
Old 02-26-2012, 04:48 PM
wtc2792 wtc2792 is offline
wtc2792 is starting off with a positive reputation.
I recently pulled my motor out of my truck. All back in but i cant find out where to hook the vacuum modulator hose too.
Old 02-26-2012, 04:57 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
It usually goes to the little plastic vacuum tree mounted on the firewall behind the engine. It can also go on any port on the intake manifold that has vacuum all the time the engine is running.
Old 02-26-2012, 07:14 PM
82f100460's Avatar
82f100460 82f100460 is offline
82f100460 is gaining momentum as a positive member of FTE.82f100460 is gaining momentum as a positive member of FTE.
mine tee's off the same connection to the manifold my power brake booster does
1985 F150 C6 auto Vacuum Module help? Huntersx 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-18-2016 10:39 AM
1988 C6 trans slow to engage into drive swhitney133 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 11-11-2016 07:15 AM
Vacuum modulator twise 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-05-2015 06:50 PM
Vacuum Modulator HillBillyBuddha 1961 - 1966 F-100 & Larger F-Series Trucks 3 03-13-2014 04:25 PM
Re - Toasted C6, bad vacuum modulator IDIDieselJohn Clutch, Transmission, Differential, Axle & Transfer Case 1 09-10-2011 09:22 AM
Tags
2001, 2003, 4x4, 82, c6, diaphragm, f100, f150, ford, modulator, set, trans, transmission, vacuum, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
