diesel tank capacity and mileage
I have a 96 f250 4x4 with the 7.3 in it. It has the dual tanks. I was wondering what capacity each tank is? I filled up a total of 29 gallons between the 2. I drove 130 miles and went through half a tank on the front tank so far. I just bought the truck 130 miles ago. Does that sound right on the mileage?
Received 3,103 Likes
on
not unless someone swapped them out for smaller tanks. stock fuel tank size on 87 to 97 ford diesel tanks is 18 front and 19 rear
there is usually a few gallons left in the tank after you run out because the pickup is not on the bottom of the tank.
All the OBS PSD's have 18.2 gallon tanks in the rear and the size of the front tank depends on the cab/bed. Regular cab 4x4 have 22 gallon front tanks. Regular, Super and Crew cab longbeds have 19.5 gallon front tanks. Super and Crewcab shortbeds have 16.5 gallon front tanks.
Mine is a Reg Cab 4x4 and I have only ever put 18 in it when she got real low. I dont like to run out so I typically fill er up about 1/8th left
El Camino Man
02-25-2013 05:49 PM
Zoltrix
02-12-2008 09:05 PM
2New2Fords
09-18-2006 09:34 PM
