I was helping the OP diagnose this noise because I was trying to figure out what would cause it. Turned out the roar in my engine came back last weekend after I got stuck pretty bad and had to rev it up to get out.
The intake tube vibrates during the roar - almost like the sound and vibration of a loose bearing at high RPMs - and when the engine begins to idle back down, it quits.
This same "roar" occurs in gear on the road at lower RPMs. I'm stumped.
Have you checked the center drive-shaft barring? I had to put the truck on a lift and then put the truck in drive to identify the problem. It can roar and make different noises at different speeds. It's easy to check, hope that helps.
I have another thought, sometimes a broken exhaust stud/studs can cause this. Excapeing air can as we all know make weird nosies and of course air will creat viberation which translates into noise.
I don't think it would be a waste of time to check the exhaust manafold studs.
If I get off work this weekend, I may tear into the air box, clean the MAF sensor, check the throttle plate and look for any build-up. Will let you know.
My bad! The black cone on the air filter element would not make its way to the throttle body but be stopped by the MAF. Still causing a turbulence in the air flow and a possible noise in the air intake.
Its your Belt Tensioner Pulley thats doing it. Mine did the exact same thing. Changed the tensioner and it fixed it. Nice and quiet again. Its pretty cheap and easy to change.
