Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-26-2012, 01:06 PM
killalldude killalldude is offline
Garage is empty, add now
killalldude is starting off with a positive reputation.
Double DIN Dash Kit?
Hello fellow Ford Owners!
I'm new to these forums, about 10 months ago I picked up a 2008 Lincoln Navigator with 28,XXX miles on it. It had practically whatever I wanted except navigation.
This weekend I installed a new headunit which has navigation. It is a Pioneer X710-BT. It replaced the factory 6-disk CD changer. I had to cut the bezel to make it fit:
Click the image to open in full size.
I cut the small bar at the top. I mounted the headunit using the mounting brackets from the stock headunit, and this is how it lines up:
The top and the sides are flush with the bezel, however there is a 1/2" gap at the bottom. Anybody know which dash trim kit that will be compatible with this?
All help is very much appreciated!
  #2 (permalink)
Old 02-26-2012, 06:14 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
The only kits I've seen for Navigators are ones that already have factory navigation. The radio bezel surround is different with factory navigation, the opening is bigger. You could try one of those kits and just trim some more of your bezel opening, or buy a whole new radio bezel = $$$$
Here is an example of the kit:
http://www.crutchfield.com/p_1209558...t.html?tp=3121
Matt
  #3 (permalink)
Old 02-27-2012, 08:18 PM
TFWcustoms TFWcustoms is offline
TFWcustoms is starting off with a positive reputation.
Check with online junkyard, I was going to do the same exact project and i was able to find the part for 150. Another option is to just glass in that section and then repaint the panel
  #4 (permalink)
Old 02-28-2012, 06:31 PM
Thanks for the help guys. Unfortunately, the OEM Navigator navigation bezel is nearly impossible to find. I'm most probably going to have someone fiberglass and paint it for me, as I have no skill with fiberglassing.
  #5 (permalink)
Old 03-01-2012, 09:12 PM
07xpyebel's Avatar
07xpyebel 07xpyebel is offline
07xpyebel is starting off with a positive reputation.
This may help you.
METRA 95-5812 2008 LINCOLN NAVIGATOR AUDIO DASH KIT RADIO INSTALLATION STEREO
Tags
150, 2007, 2008, 99, bezel, dash, din, double, e150, ford, install, kit, mpg, radio, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
