Parking brake adjustment?
I have an 05 250 XLT with all disc brakes and sometimes the parking brake will engage, and sometimes it won't.
I did read somewhere on here that there is a small drum setup inside the rear assemblies for the parking brake, but I'm not sure how to resolve this issue.
Anyone have any ideas?
I just fixed this exact same problem on my 2005. Crawl under the truck and look at the rear wheel backing plates. You should see the heads of the shoe retaining pins in the dimples on the backside of the plates. My guess is that you will see 2 holes but no retaining pin heads. This happens when the backing plates rust out.
You can find the plates online for about 27 bucks a piece. Ford will only sell you the whole backing plate/parking brake assembly.
The "backing plate rust problem" is a VERY common problem on these trucks.
If what Whalerron says is right then these are the dust shields from amazon.
They come with pins and clips but those ones are junk.
$17 at Napa gets you this hardware kit. These are the real pins and clips for grown ups.
RockAuto.com has the Dorman parts too. It seems like everyone carries the Dorman part. I didn't know that you could buy just the backing plates when I did my repair and I bought the full assemblies from Ford. I wish I had looked here first!
Also, here is a thread about this subject:
https://www.ford-trucks.com/forums/1...ng-plates.html
I got this spindle nut socket off the shelf at my local Napa. It cost me $21 and fit perfectly.
NAPA AUTO PARTS
NAPA AUTO PARTS
NAPA AUTO PARTS
NAPA AUTO PARTS
ajstephan
03-13-2018 08:16 AM
