Parasitic Drain - Instrument Cluster? Fuse #2/#41 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-26-2012, 12:35 PM
martin123456789 martin123456789 is offline
martin123456789 is gaining momentum as a positive member of FTE.martin123456789 is gaining momentum as a positive member of FTE.
Hi,
I've been having lots of trouble starting my 2005 6.0L F250 lately.
So I figured, I'd check for a parasitic current draw.
I unplugged negative on the driver side's battery, plugged in a multimeter on the 10amp setting between the post and the cable.
Unplugged the passenger side battery negative. I have a draw of 0.88A!
I figured I'd unplug fuse by fuse to find the culprit.
When unplugging Fuse #2, the draw goes down to 0.06A
When unplugging Fuse #41, the draw goes down to 0.35A
Both of those are related to the instrument cluster according to the owner's manual.
What do I do from here? Any ideas/suggestions?
Thanks
Old 02-26-2012, 02:16 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
You have to give the computers time to shut down, as well as the battery saver relay so your door and hood lights are out. Otherwise you're going to get a high reading.
When I'm testing for draw, I hook a jumper wire between the negative cable of one battery and it's battery post. Then unhook the other negative cable. Wait about an hour for all the computers to get shut down and for the hood and dome lights to go out. Connect your DVOM and then remove the jumper.
If for any reason you completely disconnect power, when you reconnect it all the computers will come up live and the dome and hood lights will come back on and you'll have to start over.
Old 02-26-2012, 03:58 PM
Thanks for the feedback! I tried it again.
Unplugged the light in the engine compartment and waited way longer.
It finally got down to 60mA, so I guess that's not my issue. :S
Old 11-09-2012, 04:29 PM
7 months later, my set of batteries is dead.
I still have this problem, I turn off everything, let the truck stand there till everything falls asleep with an ampmeter in serie with my battery setup.
I have a draw of about 0.4 amps till I pull the Fuse #2.
Fuse #35 and 41 don't change much.
Fuse #2 is the cluster, I decided to take it out and have a look.
Is this duct tape from the factory?
Thanks
Old 11-13-2012, 04:11 PM
Ok, so yes the duct tape is from the factory...
And after 45 minutes or so the current goes down to 0.05A...
However, I was measuring this at the driver side with the passenger side battery unplugged on the negative.
When I plug the passenger side battery in, I get a draw of 0.2A, 4x more! :S
(With the amp meter still on the drive side battery)
I've done another test, woken up the truck, plugged in the lamp on the hood...
I get a reading of 0.28A with two batteries plugged in and 0.88A with only one battery plugged in. :S
If the two batteries are parallel shouldn't the current just be double with 1 battery?
Any ideas on what I should test first at this point?
Old 11-13-2012, 04:43 PM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Un-hook the alternator cables and see what you get.
There is a plug and a cable. Also if the battery's
are not at the same state one will draw from the
other. This is why you replace them as a pair and
not one at a time.
Sean
1992 - 1996 parastic draw test whitey33 1987 - 1996 F150 & Larger F-Series Trucks 31 12-31-2016 08:25 PM
Parasitic draw from F21 need diagrams please!!! zackanderso01 1997-2006 Expedition & Navigator 12 09-03-2016 08:38 AM
WTF power problems sacseven 1999 to 2016 Super Duty 1 08-27-2015 08:46 PM
2003 F150 drained battery problem-partially solved sanger440 1997 - 2003 F150 2 08-02-2014 03:14 PM
Parasitic Battery Drain sledhead999 1999 - 2003 7.3L Power Stroke Diesel 34 07-10-2013 05:52 PM
Tags
02, 35, cluster, company, current, draw, fuse, information, instrument, instrument cluster, parasitic drain, powered, superduty, texas, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
