Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-26-2012, 10:13 AM
darray's Avatar
darray darray is offline
1973 Ford F-250
My Garage
darray is starting off with a positive reputation.
1960 F-100 Engine/trans upgrade to ???? Suggestions???
As instructed, the "NEWBIE" has posted a new thread..
Does anyone have suggestions (that are reasonable and attainable from a junkyard )for a viable engine/trans that can replace the 223 6 cylinder in my newly aquired 1960 F-100 utility (old ma-bell truck)
I am looking to get a good mix of economy and power for a work truck..
I am a long time ford owner 1979 the move away from other brands
1973 F-250 crew W/ 4.9 injected - good hauler, fair mileage for the size
1961 Falcon Ranchero W/ 200cid - Great runabout, excellent mileage, light dutie
I put the engines in both and I drive them daily
I also own a 1962 dodge lancer wagon that is my family car, I am second owner and it is clean and stock
Your experience and help will be great..
Thank You
Chuck
  #2 (permalink)
Old 02-26-2012, 10:24 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
Garage is empty, add now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Welcome aboard! With a stable like that, and driving them to boot, I'd hardly call you a newbie. I vote, as usual for the 300 cu in six. I did put a 302 in a '40 1 1/2 ton about 6 years ago and that fits the bill too. A lot of folks seem to think they're too gutless, but it depends what you're moving up from. Both of these are a powerhouse in my book! GB
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #3 (permalink)
Old 02-26-2012, 10:34 AM
darray's Avatar
1973 Ford F-250
My Garage
Thankx for the kudos, I was just in the process of fleshing out my garage with the other rides I have...
Regarding the truck, what trans would you put behind the 302. I would like to use a later injected model, what is the numbering of the 302 in liters ?? Would you change the rear end ??
  #4 (permalink)
Old 02-26-2012, 01:29 PM
GB SISSON's Avatar
I'm probably not the one to ask. I used a t-18 cuz I like to shift. I think the 302 is a 5.0, but someone can correct me here. I do however have all the specs on flathead v8s committed to memory. Not sure why, they just won't go away. Rear ends are all about how you want to drive it. Highest speed limit on Orcas Island is 40 mph, so stock gearing is great here.
__________________
  #5 (permalink)
Old 02-26-2012, 03:34 PM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
2losteve 2losteve 2losteve
I am running a 1990 Mustang 5.0 (302) with the stock fuel injection and the AOD trans and it's a good cruising combo for my '56. Trouble is, you don't see many low mileage versions in the yards anymore as they're getting kinda old.
What I'm planning for my '57 is a 4.6 or 5.4 Modular eng./trans out of a later Ford product. Many more to chose from nowadays.
  #6 (permalink)
Old 02-26-2012, 03:41 PM
hotfalcoon's Avatar
hotfalcoon hotfalcoon is offline
1957 Ford F-100
My Garage
hotfalcoon is starting off with a positive reputation.
Welcome! A lot depends on what you are planning on using the truck for. If you are going to use it to haul stuff and work it, I would suggest the 300 six for its low end torque with a 4 speed. If you are planning to drive it daily and want good highway speeds I would opt for the 302 and an AOD outo or T-5 manual transmission.
  #7 (permalink)
Old 02-26-2012, 03:52 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Quote:
The C-6 behind a 302 is bullet proof!
  #8 (permalink)
Old 02-26-2012, 09:46 PM
darray's Avatar
1973 Ford F-250
My Garage
what is the best donor for the C-6 trans and 302
  #9 (permalink)
Old 02-27-2012, 04:29 AM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
tbirdscott is starting off with a positive reputation.
C6's especially the sb variation are getting hard to find, look in econoline vans and larger 2wd pickups from the 80's. If your after economy more than towing and power handling an AOD will be fine for most applications
I would go with a 351(5.8l) over a 302(5.0L) any day, fuel mileage within a couple mpg and more power but it really depends on what you are going to be using it for and what speeds you need it to travel at. As for a donor 302 I would say a 1993+ mustang/explorer version would be your best starting point for performance especially is you intend to keep the EFI as the MAF system is much easier to work with than the SD.
Scott
__________________
1960 Comet mostly stock, summer DD
1979 Ranchero/Thunderbird 'Thunchero' 390 or 460 powered in the future...
1980-82 thunderbirds everywhere you look
1994 F350 IDI turbo getting a 1959 Mercury body transplant
1994.5 F250 PSD, 5spd 4" rancho on 35's
  #10 (permalink)
Old 02-27-2012, 10:35 AM
darray's Avatar
1973 Ford F-250
My Garage
Thank you for the info.
What kind of mpg do you get with your F250 light 300/ 6cyl ? ZF5
I have a 4.9/300 in my heavy F250 crew and I have great power with fair economy for the weight..
  #11 (permalink)
Old 02-27-2012, 03:17 PM
tbirdscott's Avatar
Around 17mpg, lots of highway driving and hills here so it is to the floor struggling to do highway speed all the time. 351 is going in as soon as my parts truck melts out. 300 is going to the scrap pile! Bought the truck for the rust free body. Had an bronco with the 300 and it sucked on the highway too, not a fan of the 300's at all.
Scott
__________________
  #12 (permalink)
Old 02-27-2012, 03:40 PM
GB SISSON's Avatar
what's a highway?
__________________
  #13 (permalink)
Old 02-29-2012, 06:01 PM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a good reputation on FTE.Col Flashman has a good reputation on FTE.
Quote:
Scott
Well, looks as if you never heard of making an I6 Breath Properly & that's why you can't get it to perform.
Of course you could be just another v-8 Zombie that believes that the only engine out there that can do what you wish it to, typical.
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica)
My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
  #14 (permalink)
Old 02-29-2012, 06:15 PM
spurredon's Avatar
Quote:
Originally Posted by GB SISSON View Post
what's a highway?
It is something that you can drive on after you go an hour or so away from my house!
  #15 (permalink)
Old 02-29-2012, 06:18 PM
spurredon's Avatar
That is as hilarious as it is true!
Tags
1960, 37, engine, ford, motor, trans, truck, trucks, upgrade, zoby
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
