60 F100 Dash ?
It depends on the switch/cable..
headlight switch: pull switch to on position then from backside of dash theres a small button thats easily felt...press it down fully then tug on the shaft and it will come straight out...
Vent cables...the ***** arent removable from the cable...theres a nut on the backside of each...loosen that and pull the cable forward away from the dash for masking if you are painting.
wiper switch...theres a set screw(allen head)...loosen it and the **** slides off the shaft..
The others are straight forward(cig. lighter and glove box door)
- cs65
- cs65
51f1truck
09-13-2009 10:06 AM
