Grease Fittings location - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 02-26-2012, 08:47 AM
chi6488 chi6488 is offline
chi6488 is starting off with a positive reputation.
Can someone be nice enough to photo and help me find the grease fittings I need to lube when oil changing??
I cannot find them
Old 02-26-2012, 02:04 PM
UGA33's Avatar
UGA33 UGA33 is online now
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
Only grease fittings on these trucks are on 4x4 trucks. There are two. One on each front axle shaft u joint.
Old 02-26-2012, 02:57 PM
longview1's Avatar
longview1 longview1 is offline
longview1 is gaining momentum as a positive member of FTE.
^ Didnt think there was any! Ill have to shoot a bit of grease in them two.
Old 02-26-2012, 04:02 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Confirmed...only the two.
Old 08-17-2014, 10:18 AM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Been reading a few forums regarding retrofitting Zerks into non serviceable joints in other makes and models. Are there any joints on 2008-2010 SD's that one may consider doing such?
Old 08-17-2014, 08:49 PM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
When I had my 2001 F350 I had a vibration after replacing the U Joints in the driveshaft. Ended up taking it to get balanced, they would not touch it unless they replaced the joints with OEM type joints, called the grease-able joints junk, and that was that.
Old 08-18-2014, 04:58 AM
senix's Avatar
I don't think I would touch them till needed. Then replace with grease able joints.
Greasing zerk fittings 4.9LOldFordTruck 1987 - 1996 F150 & Larger F-Series Trucks 6 01-20-2016 04:38 PM
Can't find any zerk fittings lrrbr 1999 to 2016 Super Duty 6 05-26-2014 04:24 AM
Lube/Grease fitting on top of steering knuckle? kosb 1999 to 2016 Super Duty 5 07-02-2009 05:01 PM
grease fittings? cpdorroh 2009 - 2014 F150 2 06-20-2009 09:42 AM
grease fittings renoduckman Oil & Lubrication 10 06-06-2008 07:09 AM
Tags
1983, 2004, 2006, explorer, f150, f250, f350, fitting, fittings, ford, grease, location, locations, points, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
