351W Dizzy shaft lenght differences
Hello all.
I put a 1990 351W in my ranger that was efi at one point in time before i got it. I have none of the efi parts and have no desire to source all the parts. It came with a Edelbrock performer 4bbl intake so im going carb. Now my question is that im looking for a new dizzy with vac. adv. and i found lots on ebay for a great price but it states This distributor is to used on 351W blocks that were originally carbureted. 351W engines that were fuel injected will not allow the use of this distributor. The fuel injected blocks use a longer shaft distributor. Be sure of the type block you have before purchasing.
(FORD 351W WINDSOR SMALL BASE HEI DISTRIBUTOR RED 6710-R | eBay heres a link to it)
Now every place i search says to put an earlier dizzy in with no problems but im just wanting to get all my bases covered before i commit to buying.
Thanks for your guy's help
Taylor
Taylor
Odd, first I've ever heard of it. Then again I've never torn down an EFI 351W. I reckon you could always go to Napa or something and ask to see a dizzy from an '81 and a '90 351W and see if the shaft/gear is different.
The factory Duraspark II setup is pretty hard to beat, you might look into that too.
Okay update time.
I bought that ebay dizzy and it worked great. No difference in length from what ive seen. Now as for the GM hei adapted ford dizzy, id steer clear. Im on my third one now. First one the mech. advance bearings gave out after 2 days of driving and stuck at full advance. 2nd and 3rd leaked oil through the base into the rotor. Im currently gathering stuff to do a duraspark setup for reliability.
351w, block, bs, carb, difference, differences, distributor, distributors, f150, fuel, holes, injected, injection, length, longer, questions
