Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-26-2012, 12:08 AM
fast58's Avatar
fast58 fast58 is offline
Garage is empty, add now
fast58 is starting off with a positive reputation.
Kyle Brazier
Power windows...
Has anyone ever put power windows on an old truck like ours? I have this idea of going to the pick-n-pull and gutting a couple of car doors for the power window motor and apparatus (including the window track and such). I feel confident that I could put the power window components in my truck and have power windows.
I do have a few questions though. Does anyone know how power window motors know when to stop? Do they stop when a certain amount of pressure is reached or do they have a designated distance to travel up and down? Also I am wanting to use the stock window crank in my truck as a switch, Does anybody have an idea for that? I was thinking that when I move the window crank up the window goes up and when i move it down the window goes down.
Any ideas are appreciated.
__________________
http://www.ford-trucks.com/forums/im...ine=1324186537
1958 Ford F-100. 351 W .030 over and Speed Pro flat top pistons, Comp Cams 224/226, World Windsor Sr. heads, Edelbrock Performer intake, Holley 750 carb, Roller rocker arms, Proform one-wire distributor, MSD 6-AL ignition.
  #2 (permalink)
Old 02-26-2012, 12:11 AM
ibuzzard's Avatar
ibuzzard ibuzzard is online now
In Memoriam.....
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
Quote:
They're geniuses.
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Entitled, self-absorbed kids - meh."
  #3 (permalink)
Old 02-26-2012, 09:03 AM
Rusting-Nuts's Avatar
Rusting-Nuts Rusting-Nuts is offline
1960 Ford F-100
Rusting-Nuts is starting off with a positive reputation.
Ok... For the most part power window system travel limits are built into the window regulators. In short they know when to stop when they can not travel any more. There are exceptions for express down features that look at the current draw to know when to stop the motor. But that is a bit advanced for what you want. There are aftermarket kits to convert pretty much any manual window system to power. You can buy power window switches that have a crank looking handle allready on them for the stealh look.
With the hassel involved with properly engineering your own system it it really dosen't make sense to try to homebuild it. But I am sure it could be done.
Good luck.. Jack
  #4 (permalink)
Old 02-26-2012, 02:02 PM
fast58's Avatar
Kyle Brazier
Are you saying that when the window comes to something that stops it, the motor stops moving? Like when the top of the window hits the top inside of the door it stops trying to roll up. Is that right? The reason I want to "homebuild" it is because I can get everything I need for about $50 at the local pick n pull from a new car. A cheap kit will cost double that. I would rather get something that is factory and higher quality for cheap. Plus I am majoring in Mechanical Engineering so this would be a good practice for me. But that's not to say that I have my mind set on this way. If I find that this way will be more work than it's worth then I will consider other options. Thanks for the input Rusting-Nuts.
__________________
  #5 (permalink)
Old 02-26-2012, 02:44 PM
1960 Ford F-100
Yes..that is pretty much it. Now...most new car power window systems are set up much like a garage door opener to put it in to simple terms. They work off a cable system where the motor turns a spool wraped with the cable. They are not adapted easily to other applications. The older stuff were more of a gear driven system. They worked much like a scissor jack and that style drive would be your best bet IMO.
  #6 (permalink)
Old 02-26-2012, 02:57 PM
1960 Ford F-100
I was just pondering about what you are trying to do and I am thinking about a car that just might have what you need that would make a pretty easy install. I would look at the rear doors on a Lincoln town car from about 84 to 89. I say rear doors because the fronts have those dropping mini wings. Measure the glass travel you need from your truck and make sure the car you get your parts from has at least as much. Check close on the donor to though because some of the rear windows dont roll all the way down. Just a thought.
  #7 (permalink)
Old 02-26-2012, 05:14 PM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
The power window systems I am familiar with stop when you release the switch. There are stops on the window regulator and tracks, but when the stops are hit, the motor stalls until you release the switch.
Also, sometime after 2000 some motors have sensing systems (current I guess) to cut off power if someone has an arm or hand in the way to limit injury.
  #8 (permalink)
Old 02-26-2012, 08:09 PM
1960 Ford F-100
You are correct
  #9 (permalink)
Old 02-27-2012, 11:53 AM
fast58's Avatar
Kyle Brazier
Okay that sounds good. Nice to know the motor stops on resistance rather than at a designated point because that would complicate things quite a bit. I'll have to check the junk yard out and see what would work best. It may end up cheaper to buy the whole door instead of individual parts. I will have to keep researching and see. Keep throwing ideas or suggestions at me.
__________________
  #10 (permalink)
Old 02-29-2012, 02:18 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
i made my own power windows using parts from the wreckers. you need the motors from a mid 80's vehicle. there are two different styles that will work. the older style has the large round motors, while the newer ones have the flat style motors and are preferred. doesn't really matter what vehicle as Ford used them on a variety of vehicles.
all you have to do is remove the crank assembly from the window regulator (it is riveted to the frame) get a piece of 3/8" thick flat bar, shape it to go around the gear on the power window, drill holes to attach to the power window motor and holes to attach to the old window regulator. once you get the window regulator out of the fridge and get the power window regulators and have a look at them, you will be able to see quite easily how everything needs to go togather. the gear on the power window is the exact same gear as on the hand crank. the only thing that you will have to do is on the passener side, to fit the motor and regulator in, you will have to cut away some of the inner bracing to make it all fit.
it is a really simple project once you take everyhting out and lay it out.
the big gear on the regulator for the window will only allow the motor to go so far before it hits the built in stops.
rgds
Mike
  #11 (permalink)
Old 03-01-2012, 10:56 AM
fast58's Avatar
Kyle Brazier
I think I pretty well understand what you are saying. But you lost me when you started talking about window regulators in the fridge. It doesn't have regulators because it doesn't have power windows. When I think of a window regulator I think of an electronic mechanism that controls how fast the window goes up and down. Are you calling regulators what I think of as window track apparatus? With the big gear looking thing and scissor lift kind of a deal? Thank you for the input. It's reassuring to know that I'm not the first person that wants to do this and it is relatively easy to do. Please correct me if I'm wrong.
__________________
  #12 (permalink)
Old 03-01-2012, 12:33 PM
the window track apparatus with what looks like a semi circle gear. that is technically still a regulator as a regulator can be either manual (hand crank) or electric as you are talking. once you get it out (or better yet find a spare set to experiment with) it will all make sense of how it goes togather and where the flat bar mounts.
Rgds
Mike
  #13 (permalink)
Old 03-02-2012, 02:49 PM
fast58's Avatar
Kyle Brazier
Okay thank you. I will have to search the junk yards for a donor car. Will I need just the apparatus and motor and switch or should I get the whole door. A door at the local pick n pull cost $40. That way I would have everything I need.
__________________
  #14 (permalink)
Old 03-05-2012, 04:44 PM
just the motor and switch is all you need. wiring is fairly simple as the motor is just two wires. make sure you get the switch that has i think it is 4 or 6 terminals . the older style chrome toggle style switch (looks the same as they used in the GM cars) are the ones i used and they can be found in the mid 80's mustangs as that is where i got mine out of. the newer switches uses remote relays to reverse the motors, while the old switches just reverse polarity in the switch to reverse the motor.
you can get the whole door if it is easier to remove and that way you can see how the wiring is, but you won't need anything but the motor and switch in the end (although the wiring harness would be nice).
goof luck
Mike
  #15 (permalink)
Old 03-05-2012, 07:06 PM
fast58's Avatar
Kyle Brazier
Okay. That sounds easy enough. I won't need the window track or anything?
__________________
Tags
1958, antique, companies, f100, ford, forum, limit, motors, power, powered, put, regulator, stop, truck, vbulletin, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
