1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
what's the minimum lift for 40" tires????
Old 02-25-2012, 09:22 PM
HASBROUCK's Avatar
HASBROUCK
HASBROUCK is offline
Hey guys I just bought a set of 40x15.50r22 toyo open countrys to start my lift I was just wondering what size lift I can squeeze these tires on
Old 02-26-2012, 04:11 AM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Unless you use Bushwacker "Cut-Out" fender flares, 40" tires typically require a 10" lift kit. Because you converted your front end to the 2011+ Super Duty, you have eliminated the "Cut-Out" option because Bushwacker doesn't make them yet for the 2011+ Super Duty. With the 15.5" wide tires, you will need some fender flares for protecting that new green paint. I would recommend Bushwacker "Pocket" style fender flares (1999-2007) in the rear and (2011-2012) in the front.
Note: You may be able to use the Bushwacker 2011+ "Pocket" fender flares on both front and rear. This would be your best option!
1999-2007 Rear "Pocket" Fender Flares:
2011-Present Front "Pocket" Fender Flares:
Old 02-26-2012, 04:35 AM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
8"-10" should get you there. your choice of rims is really where you will get the most gain or loss. I've got 12" of clearance with my 4.5" kit and 35x12.5" rubber. My rims give me over 2" of clearance side to side as well with full lock.
those wide tires are going to make things tough
I second the flares though. you'll need the extra wide ones and probably some extra rubber to keep from slinging stuff down the side
Old 02-26-2012, 09:49 AM
HASBROUCK's Avatar
HASBROUCK
I probably not gonna put flares on it. currently I'm gonna use my 22x10 -26 offset wheels till I get the 22x14 -76 wheels I haven't chosen yet.but I've been hearing 8" to 12" Is the minimum I'm just curious what you guys think
Old 02-26-2012, 01:52 PM
Ian123's Avatar
Ian123
Ian123 is offline
If you plan on running a 22x14 with 40's you will need at least 10" of lift. I've seen it done with 8" and the front bumper was shimmed out way far and the back part of the fender had to be trimmed a lot.
Old 02-26-2012, 04:26 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
10" to run em, more if you plan to flex the front end at all...
Old 02-26-2012, 05:26 PM
HASBROUCK's Avatar
HASBROUCK
Yeah i was thinking a 10 maybe a 12 but aren't there problems with the driveshafts past 10"
Old 02-26-2012, 05:45 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
you are going to start hitting driveshaft and brake-line issues with 8" and higher lifts
considered a body lift? if you don't use the truck as well...a truck, a body lift would be a nice economical way to get some height. a good quality 6" lift + 3" body will get you where you need to be
Old 02-27-2012, 08:26 AM
VONxRUBENxLA's Avatar
VONxRUBENxLA
VONxRUBENxLA is offline
My buddy had a 12 on his 01 with 41's i will post pics later
Old 02-27-2012, 11:10 AM
Furian's Avatar
Furian
Furian is offline
In your case, you have a GEN1 (1999-2004) suspension. You installed a GEN4 (2011-Present) front end. While I do know that the GEN4 front wheel wells are the largest available for any Super Duty, I don't know if Ford increased the size of the GEN4 rear wheel wells. You have the GEN1 rear wheel wells on your Super Duty.
40" tires are larger than the OEM front and rear wheel wells so you have to have sufficient lift to avoid damage to the body. If you are off-roading, even more lift is required due to flexing of the truck.
TruckToyzPerformance.com has a "Gallery" where you can select the appropriate criteria for your desired application (see link below). Here are a few examples of GEN1 Super Duties with 40" tires. Note the clearance at both the front and rear wheel wells.
http://www.trucktoyzperformance.com/...earch-blue.php
Example 1: 12.5" Lift Kit - 40" Tires - 20" Wheels
Example 2: 12.5" Lift Kit - 40" Tires - 20" Wheels
Example 3: 9" Lift Kit - 39.5" Tires - 20" Wheels
Example 4: 10.5" Lift Kit - 39.5" Tires - 20" Wheels
There are many other trucks in the gallery, many of which are GEN2 (2005-2007) or GEN3 (2008-2010).
Old 02-27-2012, 11:53 AM
HASBROUCK's Avatar
HASBROUCK
this one says its a 10" lift with the 22x14s on 40x15.50r22
Old 02-27-2012, 04:27 PM
HASBROUCK's Avatar
HASBROUCK
I'm loving these moto metalthat just came out 22x14 -76 offset
Old 02-27-2012, 05:43 PM
VONxRUBENxLA
That thing is tough!!!!!!!!!!!!!
Old 02-27-2012, 06:14 PM
HASBROUCK's Avatar
HASBROUCK
These guys down in va buy trucks and redo them and sell em its called davisautosales.com I think
Old 02-27-2012, 09:07 PM
Furian's Avatar
Furian
Furian is offline
That's a clean looking design... nice!
Quick Reply: what's the minimum lift for 40" tires????
