what's the minimum lift for 40" tires????
I would also recommend a full hydraulic steering system with those wide tires.
Complete Full Hydraulic Kits - Full Hydraulic Steering - Offroad - Motorsport Specific Products
I actually cheated. Used a green vinyl, 4 hrs of sitting on the couch wrapping them! Wasn't sure if i was going to like it or not but i couldn't be happier with the results. Has held up very well so far.
I was running 38's with a 9'' lift but a buddy wanted to trade me for a more less new set of 40s.
Had to trim the front bumper on the lower corners and i did cut some material out of the back fender. I then heated up the flares and pushed them back so the tires wouldn't grab them under large bumps.
I have not had any rub issues since. Even at full lock hitting bumps i have not had a issue. That being said i wish i would of went with a 10'' lift just for peace of mind.
My wheels are rbp 18x10 with a -25 offset.
I could of went with cutouts but i'm not really a fan of them.
OEM Steering Box - $309.18 from PartGuyEd.com
2003 FORD F-250 SUPER DUTY Parts - www.partsguyed.com
Quality Dual Steering Stabilizers - $309.95 from TopgunCustomz.com
99-04 Ford Super Duty F250/F350 Dual Steering Stabilizer Black with Bilstein Cylinders @Top Gun Customz
Icon Cross-Over Steering Kit - $854.44
39500 - Late 1999 - 2004 Ford Super Duty F250 / F350 Cross Over Steering Kit - ICON Vehicle Dynamics
I am in the process of purchasing parts for a 40" tire install and lift kit for my 2005 F350 4X4. I contacted PSC and was informed that all I needed was their SKR500 kit and have my OEM steering box "ported" for the conversion. The cost was $507.00 plus shipping. However, the link for the SKR500 kit is no longer valid. I would contact Kevin Jackson at PSC and see what components are available for your Super Duty.
Here is the email response from PSC.
From: Kelvin Jackson [mailto:kelvin@pscmotorsports.com]
Sent: Monday, January 10, 2011 12:05 PM
To: a1saine@adelphia.net
Subject: RE: PSC Motorsports: User filled in Contact Us form!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
You will need to send your gear in for us to port it. It runs $507 plus shipping for the ported gear, cylinder with hardware and hoses. I would replace the pump with a new factory one and you should be good to go.<o></o>
<o> </o>
Kelvin Jackson
PSC Motorsports<o></o>
817-270-0102<o></o>
The benefits (other than better control over the wide tires) are that you will not need the dual steering stabilizers or the cross-over steering kit.
#28
Full hydro steering is illegal for on road use. You need a mechanical link for front on road steering. Hydro assist would be nice though.
