2003 Explorer 4.6L 2WD High Idle problem - Ford Truck Enthusiasts Forums
Old 02-25-2012, 09:39 PM
Michael Moran Michael Moran is offline
Michael Moran is starting off with a positive reputation.
Hello all! I am working on my friends 2003 Explorer 4.6L 2WD automatic with 96K. About 6 months ago I did some routine maintenance on it. Plugs, pcv valve and air filter. No problem. Now the issue I am having was a low idle and occasional stalling. No problem. I looked to the forum and soon found the elbow from the pcv hose cracked. Replaced that. Looked for additional leaks with starter fluid...found none. Took it for a drive. High idle. If it goes above 2000 rpms it stays there for anywhere between 20 to 60 seconds before going to a low idle 5-600 briefly like the computer is trying to find the idle speed. Then normal idle. 6-700 rpms. No codes. If I unplug the IAC is lowers to 5-600...indicating no problem with the IAC. If I unplug the MAF it settles about 150 lower on the rpm. The MAF, IAC and TPS all show proper voltage. I can duplicate the problem every time by bringing the rpms above 2000. Cold it doesn't stay high as long as when it's warm.
I have no idea.
Any input would be appreciated.
Oh and trying to find the elbow for the PCV was a joke. This motor must be mid year because none of the books even list it. The autozone guys are genius's right? "if the book doesn't list it there isn't one" As I hold it in my hand. >:-\
Old 02-25-2012, 11:48 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Connect a vacuum gauge and go look for the leak...
PCV maybe? Leaky brake booster? Loose or damaged intake tube from filter to throttle body (Any illegal air)..
Do you have a live data scanner?? ..Philip
Old 02-26-2012, 12:07 PM
I just pulled the PCV. Looks nasty and the elbow there doesn't look so hot...going to try that. I do not have a fancy tester just the pocket code reader. I'll post again here as soon as I get back... Thank you!
4.6 codes 2195 and 2197 sublauxation 1997-2006 Expedition & Navigator 6 09-25-2015 11:33 PM
High idle after cleaning Throttle Body FIXED! F91 1997 - 2003 F150 16 10-11-2014 10:34 AM
2003 f150 4.6 high idle, ludging and hard shifting manchu76 Modular V8 (4.6L, 5.4L) 2 07-12-2013 03:05 AM
2003 f-150 4.6l high idle at startup herb76 1997 - 2003 F150 2 03-31-2013 09:52 AM
Idle problem, AC Frank Gutierrez Escape & Escape Hybrid 9 06-13-2012 07:43 PM
Tags
2002, 2003, 46, 46l, adjustment, econoline, explorer, ford, high, idle, low, mountaineer, problems, sport, trac, v8, xplorer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
