Probably why so many plugs get improperly torqued as well, all the swivels used. I replaced the plugs on my '01 Engine with it sitting on my garage floor an couldn't do it without taking the rails off unless I wanted to use several swivels.
On my old 97 with the 5.4, the fuel rail had to go.
Interesting. I just did some work on my '97 F250 (had a blown spark plug) and I didn't have to move the fuel rail. I wonder if they did a mid-year change on the fuel rail.....
Driver's side was the PITA. Passenger side was easy and didn't require the rail to be moved.
