timing running me crazy
Ok let's see : 1990 f250 4x4 5.8 , set # 1 piston at TDC on compression stroke then set timing pointer to 0 , then installed dist. Rotor pointing at 1 on dist cap. Hooked up plug wires and it will start and run BUT it has no good throttle response AND I can't set timing with the timing light because 10 BTC is on the very top and if I turn dist to get 0 down to pointer the RPM's will be at 2500 rpm. Next step please ?
By moving the wires one spot, I think you would effectively advance the timing 22.5 degrees. You would think 45 degrees, but the crankshaft makes 2 revolutions for every revolution of the camshaft which drives the distributor. Kind of a moot point.
The only thing I can think of as to your actual problem is that whoever assembled the engine got the timing chain(camshaft and crankshaft marks) off a notch or two. Unfortunately that is not as easily corrected. Of course this is just a guess.
The slipped balancer would be the easiest to check. Take the number one spark plug out and stick something SOFT like a straw in the hole and determine when the piston is at it's highest point. The blancer should then show top dead center. Don't put anything in the spark plug hole that could fall in and cause harm.
To check what I said under No.7. Line it up like you did originally, pointing the rotor as close as possible to the number 1 distributor cap terminal with the balancer marks set at top dead center or 10 degrees ahead. Then start the engine check with the timing light and spout connector out. This would never read exact but should be somewhere close.
