sterling 10.5 rebuild? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-25-2012, 12:14 PM
powerstroker02 powerstroker02 is offline
powerstroker02 is starting off with a positive reputation.
hey i need some help with finding torque specs for this rear end in my truck. and also need to know how to set up the wheel bearings. right now there is just a housing under the truck i have all new bearings on the carrier and pinion gear also have new wheel bearings and seals. the spider gears in this rear end picked up on the pin and made metal then in turn destroyed a carrier bearing and wrecked everything! any info would be great thanx
Old 02-25-2012, 03:12 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
Differential Caps: 88 ftlb
Pinion bearing torque (new bearing): 16-29 in lb
Wheel Hub
Left hub has left handed threads, right hub has right handed threads
CAUTION: Install a new hub nut if the hub nut comes apart during installation. CAUTION: Make sure the hub nut tab is located in the keyway prior to thread engagement. Install the hub nut on the spindle.
CAUTION: Under no circumstances are power tools to-be used when performing these operations. NOTE: The hub nut will ratchet as torque is applied. Tighten the hub nut, rotating the rear hub occasionally while tightening.
Tighten to 60 ft lbs
Adjust hub nuts as follows:
For new bearings, ratchet back five teeth or notches (1/8 turn) on the hub nut. Five notches must be felt during this operation in order to have performed it correctly.
For used bearings, ratchet back seven teeth or notches (1/6 turn) on the hub nut. Seven notches must be felt during this operation to have performed it correctly.
Old 02-26-2012, 11:16 AM
TeamMudd TeamMudd is offline
TeamMudd is gaining momentum as a positive member of FTE.TeamMudd is gaining momentum as a positive member of FTE.
if you need an install kit (mini- install, seal, shims, carrier bolts ect) PM me, i have one for a 10.5 that i never ended up using.
Old 10-01-2012, 02:35 PM
sweetfarm sweetfarm is offline
sweetfarm is starting off with a positive reputation.
axle nut torque
Wheel Hub
I am having a hard time "feeling " the clicks when loosening the nut after torquing it. How do I do this?
Also i read in another thread 3 clicks for used bearings. Is 7 clicks correct?
Worn Carrier Bore? Driven71 Clutch, Transmission, Differential, Axle & Transfer Case 2 09-10-2015 08:40 PM
Need help with 8.8 rear end. FordPurpleRanger 1987 - 1996 F150 & Larger F-Series Trucks 11 05-19-2015 07:32 PM
Rear end bearings. Fellenz 1961 - 1966 F-100 & Larger F-Series Trucks 11 05-13-2014 08:09 PM
popping from the front end ford303 2004 - 2008 F150 1 04-29-2013 09:49 PM
10.25 rear end carrier bearings / races nomad221 1994.5 - 1997 7.3L Power Stroke Diesel 14 05-29-2012 01:24 AM
Tags
105, exploded, ford, hub, nut, rebuild, specs, spindle, sterling, tools, torque, trucks, view, wheel, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
