'91 F-250 Dual Tanks, sputtering front tank.
Howdy,
So I've got this truck, its a 1991 F-250 7.5l that runs on gas. It has dual tanks and when I switch it to the fron tank, it sputters like its getting a little sip of fuel, but nothing else. Eventually this will stop and I can't run it all together on the front tank. Could this be fuel pump, clogged lines or something else? Thanks
I stand corrected... I was meaning the pump in the front tank, and I thought the gassers had a selector valve like the diesels. The gas trucks have no selector valve. The functions of the selector valve are taken care of with valving in the fuel delivery modules (fuel pump assemblies) in each tank.
Thanks for correcting me!
Back to Jonny G's problem, it really looks like the fuel delivery module in the front tank...
Phy
Phy
Phy
Phy
If there is an open or a short circuit in the fuel pump circuit the PCM will usually store a code. That is why it is important to check for stored (CM) and Key On Engine Off (KOEO) codes before tossing parts at a problem.
Since I am pretty green when it comes to Ford trucks, and cars in general, I thought I would share as much information as possible. Thanks guys!
somethingclever
01-26-2009 04:56 AM
jratbike
12-28-2007 05:12 PM
Wynn96
11-09-2007 08:59 PM
