Ford Part Number for Pinion Seal and Rear Axle Seals
the first place I would look
Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com
on
Thank you for replying. With the DRW I do have a Dana 80 with 11.25 RG correct? Do you know the Motorcraft part number. I found the rear axle seals are BRS-12, but I can't find the pinion seal Motorcraft number. Thank you. What is a torque multiplier?
I am not sure but by looking at this and the part #'s it is the same as a standard Dana80. http://www2.dana.com/pdf/AXIP-0076.PDF I take that back the ring and pinion gear are different.
Hopefully someone who knows more will weigh in on this.
Then I found my bill of material number on my rear axle and went to http://www2.dana.com/pdf/X510-2.PDF. I went down to the bottom and found Ford 80/286 and looked for my vehicle then matched the bill of material number. Here I found for sure that the spindle nut is reversed on the drivers side shaft assembly. This is an easy way to find out.
I also found out if you are having vibration problems in your driveline after you are sure your carrier bearing and u-joints are good and the shaft is not dented or unbalanced. Replace the rear driveshaft tube that has that harmonic damperer on it. It is a hidden problem when the rubber gets old.
