Hard Tranny Shift between 2nd & 3rd - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-24-2012, 04:38 PM
Gufunk's Avatar
Gufunk Gufunk is offline
Gufunk is starting off with a positive reputation.
Hi
I just got a new to me 99 f250 5.4 V8 SD XLT 4x4 Auto Trans longbox 118k miles. Before i bought it a had a trusted mechanic check it out and said it was solid except for a hard shift between 2nd and 3rd gears. When accelerating 1st to 2nd is super smooth and 2-3 is pretty hard(feel a hard jerk in my seat) and the rest of the gears are smooth as well. The mechanic didn't know what would cause that with are looking deeper into it. They said the fluid looks good and it is the original tranny does not looked to be rebuilt. Any ideas?
The OD light works and does not blink with hard shifts.
Fluid is full and does not smell burnt.
Mechanic says there are no codes.
When starting rpm's go up to 1500-2000 hold for 10-15 sec and then slowly go down
Old 02-25-2012, 06:37 PM
christopherdrop's Avatar
christopherdrop christopherdrop is offline
christopherdrop is starting off with a positive reputation.
Had the same happen to me once. It was the shifter not finding "D" fully. Only hard shifted as yours did. i can replicate it by putting truck inbetween D and 2. Drive, hard shift then put in D and it's very hard shifting (and blinking OD light).
I stop, turn off truck. Try again with shifter (which is sloppy) firmly in D and no problemo.
Hope this helps (or my tranny is ready to explode, I dunno).
Old 02-25-2012, 09:21 PM
skoepper's Avatar
skoepper skoepper is offline
skoepper is starting off with a positive reputation.
I had a sloppy shifter too - just did this fix today, made a huge difference
http://www.ford-trucks.com/forums/10...ml?ref=esp-img
Old 02-25-2012, 09:34 PM
Gufunk's Avatar
Thanks for the link i will try that tomorrow.
Old 02-26-2012, 01:21 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
Gufunk let us know what you figure out, my truck is doing the same thing between 2-3 shift. Tried all the normal stuff already, cleaning the trans fluid, cleaning the electrical connections, steam cleaned the valve bodies and separator plate to no luck
Old 02-26-2012, 01:58 PM
Gufunk's Avatar
Everything was tight under the panel. There is a little cable that you can adjust...looks like a little black wheel with ***** to twist up and down to change the tension on something. Any ideas what that is? I might take it to a shop to see if they can give me any ideas.
Old 02-26-2012, 02:54 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The little black wheel adjusts the pointer on the dash.
Old 02-26-2012, 03:28 PM
Gufunk's Avatar
Thanks Mark i see that now after i moved it a little. I hear your the resident transmission guy to you have any suggestions for me?
Old 02-26-2012, 09:26 PM
No, I don't. I have been following this thread but nothing comes to mind.
Old 02-27-2012, 09:24 AM
my shifter is tight with no slop at all, yesterday i messed with the adjuster **** under the colum and it didnt help at all. I also removed the plug that goes into the solenoid pack and sprayed electrical cleaner in them, blew it out with the air compresser and added dialetric grease, reinstalled and took a test drive. Still has that dam 2-3 clunk shift just like the OP's truck. I was doing some searching lat night on the web and found this
Sun Coast Diesel Transmissions - Ford 4R100 Non stick 2-3 shift valve 1989-2003 | Catalog Products | Sun Coast Diesel Transmissions
im gonna call them today and see if it fixs the harsh 2-3 shift
Old 02-27-2012, 10:42 AM
Gufunk's Avatar
Hopefully that does the trick. I will be curious to hear what they say.
Old 02-28-2012, 04:48 PM
Gufunk's Avatar
Hey SuperDutyScaler make any headway on your trans problem? I talked to a couple guys but they didn't know what the issue was either with mine.
Old 02-29-2012, 10:09 AM
no sorry, i went to the doctor monday morning and i have strep throat somehow so my throat is really killing me the past few days. But i was gonna call today and talk to someone over there, if not i was maybe gonna call Brian from BTS. Ive read he's awesome to speak too about problems with the 4r100 and maybe he can send me in the right direction, if not i guess its time for a rebuild? I do know i dont read any problems like this with the diesel guys, it seems like its always the 5.4 powered trucks that have freaky shift problems?
Old 02-29-2012, 10:11 AM
Gufunk how long has your truck been doing this? mine has been this way for almost two years now! So i dont think its the trans letting go anytime soon, if it is its one badass transmission then to last that long
Old 02-29-2012, 10:41 AM
Gufunk's Avatar
I have no idea how long i just bought the truck less than a week ago. Well anyway that is good news cause i have no money to do a rebuild right now.
Hard shift between 2nd and 3rd Brenda Lamka Explorer, Sport Trac, Mountaineer & Aviator 12 11-26-2014 08:34 PM
tranny question jpeckham Clutch, Transmission, Differential, Axle & Transfer Case 12 03-11-2013 03:12 AM
New 99 F250 with hard shift Gufunk Modular V8 (4.6L, 5.4L) 2 02-28-2012 04:54 PM
97 auto-transmission shifting hard menze46 1994.5 - 1997 7.3L Power Stroke Diesel 3 06-14-2010 05:10 PM
99 f150 trans hard shift zamunda 1997 - 2003 F150 17 01-29-2010 03:31 PM
Tags
2000, 2001, 2nd, 3rd, duty, f250, ford, gear, hard, heavy, jerking, jumps, shift, shifts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
