Hard Tranny Shift between 2nd & 3rd - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-29-2012, 12:37 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
here's another question, when does your truck shift? Mine shifts at 4700 to 4800rpm? which is low compared to all the you tube videos ive been looking at????
Old 02-29-2012, 12:42 PM
Gufunk's Avatar
Gufunk Gufunk is offline
Gufunk is starting off with a positive reputation.
Well if i'm accelerating normally in town it shifts about 2k or 2.5k rpms or 30-40mph, a little higher if i'm on the gas. If i'm going slow under 30mph it shift about 2k rpms. Another note it is a much harder shift at higher rpms which is what i would expect, almost normal under 30mph.
Old 02-29-2012, 01:13 PM
thats about right for normal driving, mine is a little rougher in the 2-3 all the time. And normal under WOT shifts, when does your truck shift during wide open throttle? I just posted about mine being low at 4700rpm when ever truck i drive or seen on you tube is at 5000 to 5100rpm shifts
Old 02-29-2012, 01:16 PM
Gufunk's Avatar
I don't know never had it at open throttle before, will try to do that today. We just got 6" of snow i'll try it this afternoon after its melts a bit.
Old 02-29-2012, 01:32 PM
yea dont do anything that will make you crash your new truck! Im calling Sun Coast Transmissions now to speak to someone about that 2-3 shift valve
Old 04-08-2012, 11:00 AM
thought id bring this thread backup, to the OP did you ever fix your 2-3 hard shift yet? Ive talked to two shops and i get the same answer, Fords autos suck you have almost 100k its time for a rebuild!
Old 02-28-2013, 10:58 AM
kameronth's Avatar
kameronth kameronth is offline
kameronth is gaining momentum as a positive member of FTE.
Mine has a hard shift between 2-3 as well. So hard it feels like the truck got rear ended and the serpentine belt squeals. If I turn off my 5 Star it will slip slightly but not shift hard at all. I am pretty sure this is due to worn clutches and since the tune increases the line pressure it causes a harder shift to make up for the slipping. Pulling my tranny out tomorrow and doing a rebuild. I'm curious to see how bad my clutches are.
Old 03-04-2013, 12:19 PM
droldsmorland's Avatar
droldsmorland droldsmorland is offline
droldsmorland has a good reputation on FTE.droldsmorland has a good reputation on FTE.
http://www.ford-trucks.com/forums/12...-3+shift+4R100
Have a look at the second page on this thread. If the link doesn't work put hard 2-3 shift 4R100 into the search box and look for the link dated 1/22/13 by maxfam.
Old 10-17-2013, 07:43 PM
kerrycupp kerrycupp is offline
kerrycupp is starting off with a positive reputation.
I have a 03 fx4 super cab it down shifts hard I've changed the trans filter changed the plugs and wires truck has no leaks at all the hard shifting is driving me nuts
Old 10-17-2013, 08:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Have it scanned for codes. And not at an auto parts store, they can't read the codes that you need.
Old 10-17-2013, 10:40 PM
after fixing my trans issues and talking to Brian from BTS seems the 4R100 have alot of issues. Most of the time being a bad or broken shift spring, i installed a transgo shift kit and even though i didnt find a broken spring the transgo kit COMPLETELY fixed my weird shifting issues
Old 12-29-2013, 08:39 AM
Grizzly4x4's Avatar
Grizzly4x4 Grizzly4x4 is offline
Grizzly4x4 is starting off with a positive reputation.
Quote:
Mine will hard shift from second to third if I am accelerating but let off the gas before it shifts. How hard is it to install the transgo kit?
Hard shift between 2nd and 3rd Brenda Lamka Explorer, Sport Trac, Mountaineer & Aviator 12 11-26-2014 08:34 PM
tranny question jpeckham Clutch, Transmission, Differential, Axle & Transfer Case 12 03-11-2013 03:12 AM
New 99 F250 with hard shift Gufunk Modular V8 (4.6L, 5.4L) 2 02-28-2012 04:54 PM
97 auto-transmission shifting hard menze46 1994.5 - 1997 7.3L Power Stroke Diesel 3 06-14-2010 05:10 PM
99 f150 trans hard shift zamunda 1997 - 2003 F150 17 01-29-2010 03:31 PM
Tags
2000, 2001, 2nd, 3rd, duty, f250, ford, gear, hard, heavy, jerking, jumps, shift, shifts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
