2003 F-350 6.0 Rough Idle - Ford Truck Enthusiasts Forums
Old 02-24-2012, 12:07 PM
Frankenstein2003 Frankenstein2003 is offline
Frankenstein2003 is starting off with a positive reputation.
I am wondering if anyone has had experience with rough idle and producing high egts. We replaced the ficm (not currently flashed to truck) a little while ago and it ran good. The other day it started running real rough and missed real bad. Went out to start it today and after cranking forever, it started up and ran fine. After about five minutes it was running real rough and the egts were over 500. Then it died and won't start. I added Stanadyne to the fuel thinking that maybe an injector could be plugged. I'm new to this whole thing so any input or advise would be much appreciated. Thank you.
Old 02-24-2012, 12:20 PM
powerstroker100 powerstroker100 is offline
powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.
what is your High pressure oil PSI?
any way you can see your icp or ipr values?
Old 02-24-2012, 12:36 PM
No way for me to know. I have no clue, diesel rookie.
Old 02-24-2012, 01:26 PM
It just ran for 10 minutes and died. What should I look into?
Old 02-24-2012, 05:41 PM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
Most likely high pressure oil system leak, but could be a few other things as well.
Unless you are willing to purchase a whole bunch of diagnostic equipment, you are better off just taking it to a reputable diesel mechanic and see what the issue is. If you think you are up to it, you can then make the repairs yourself.
Old 02-24-2012, 09:08 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Power Stroke Diesel forum.
Old 02-24-2012, 09:25 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
I would start with scanning for codes see if you get a Hit there
start looking into a SGII to get some readings or better yet AE
do you by chance have an OEM Oil Filter cap or AM
WRONG OIL FILTER CAP CAUSING UNFILTERED OIL TO TAKE OUT THE IPR
http://www.ford-trucks.com/forums/11...lew-again.html
Both styles in this thread you want the short octagon one check it out
Old 02-24-2012, 10:04 PM
I have an Edge Juice w/Attitude and I haven't had any codes pop up. The filter cap I believe is the original one. Tonight the egt went to 540 it ran for a little while and died. I had to crank it over for awhile with the charger just to get it to start. I really do appreciate the help. Been a bad week.
Old 02-24-2012, 10:26 PM
BLADE35's Avatar
start going threw this and post results
http://www.ford-trucks.com/forums/87...condition.html
These trucks are pretty complex so a Gauge to watch the operating systems is Best Bet if nothing easy comes from the List
Old 02-26-2012, 10:18 AM
I had heard some things about low fuel pressure could possibly cause higher egt. Is this true? The fuel pump doesn't sound the best as it is running. I ran some tests that I could.
Batteries are good
Charging system is good
Injectors buzz good at koeo
The ficm was replaced not long ago
The oil level is good
Coolant level is at min
Pulled code U0306 so I'm guessing that I need to have the ficm flashed to the ecm
Injector 7 clip is broken
Shows contribution balance fault at random cylinders
I noticed that the center clip on the ficm is broken and can be pulled right out, it was tight but it still bothers me.
I tried to test power coming to the fuel pump but I am not sure what it should read.
Any help would be greatly appreciated as I will be under the hood and truck for the majority of the day. Thanks again
I'm thinking this is why it is called Frankenstein!!
97 running rough wildstang 1994.5 - 1997 7.3L Power Stroke Diesel 7 09-12-2016 12:13 PM
88 351 windsor rough idle bogs down btubbs 1987 - 1996 F150 & Larger F-Series Trucks 5 06-30-2015 07:41 AM
2002 Excursion 7.3, Rough idle and no power HELP!!! Tyethornton 1999 - 2003 7.3L Power Stroke Diesel 31 12-15-2014 12:30 PM
6.9 rough idle & surging but starts & runs good??? ZombiePopper Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 10-01-2014 11:59 AM
1996 F250 4x4 starts, idles rough, dies in gear mustangnewby 1987 - 1996 F150 & Larger F-Series Trucks 9 08-19-2014 02:01 PM
Tags
04, 2003, 2006, 2010, 350, 60, diesel, erratic, f350, ford, idle, rough, ruff, running, update
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
