Lets see your engine now !
  #61
Old 03-13-2012, 12:07 PM
SanDiego56's Avatar
SanDiego56
SanDiego56 is offline
Originally Posted by jimcar-9
It sound like a motor I really could have in my tryck. I am leaning more and more towards a cool looking y-block like yours.
What valve train are you running, old stock with 1.54 or the billet one with hard chromed shaft from mummerts?.
Regarding the pistons what pistons did you start with (from JE) I could find any specific for y-blocks.
Thanks
My valves were rebuilt but i used the mummerts billit rocker stands, as for the pistions it was a custom job, i sent them one of mummerts aluminum heads and they went from there, job # 822463 hope this helps...
dustin
  #62
Old 03-18-2012, 06:55 PM
rustyrelic's Avatar
rustyrelic
rustyrelic is offline
5.9 Cummins out of a 94 f700 giving new life to a 56 f600.
  #63
Old 03-19-2012, 10:04 PM
ZFLASH's Avatar
ZFLASH
ZFLASH is offline
Originally Posted by ZFLASH
L8R ZFLASH
Well guys, this one locked up on me today . What sucks is I just got it out of the shop last Thursday, cut out and redid the rear frame and axel . This means this might have to sit awhile sent I just spent all that $$, been looking at crate engines tonight. Just can't decide, Chevy, Ford, Carb, or fuel injected Ls3. Keep ya'll informed L8R ZFLASH
  #64
Old 03-19-2012, 10:37 PM
Mercury Bluz's Avatar
Mercury Bluz
Mercury Bluz is offline
One of the flatties lying around the garage.
Can't seem to attach a pic....
  #65
Old 03-21-2012, 08:51 AM
needhelp49's Avatar
needhelp49
needhelp49 is offline
really should clean it up but with these trucks you can't see it anyway.
  #66
Old 03-26-2012, 03:32 PM
cts1954's Avatar
cts1954
cts1954 is offline
I kept the original flathead with a few extra. Notice the SAE aluminum finned heads, might be the only ones in existance. Dual Strombergs and it sounds better than it looks.
  #67
Old 03-26-2012, 04:44 PM
Ravenheart's Avatar
Ravenheart
Ravenheart is offline
No laughing, ok?
Jessie
Julie
  #68
Old 03-26-2012, 07:25 PM
Harrier's Avatar
Harrier
Harrier is online now
Ravenheart, are they running? You can't laugh if they are running.
Although, I might hold that thought until you tell me what the 2 liter soda bottle is for on Jessie.
  #69
Old 03-26-2012, 10:09 PM
iwanaflattie's Avatar
iwanaflattie
iwanaflattie is offline
sweet mother of Growl.!that is pretty
  #70
Old 03-26-2012, 10:16 PM
wilsel's Avatar
wilsel
wilsel is offline
Just an old 289, 2 barrel. I keep it clean though!
  #71
Old 03-26-2012, 10:18 PM
huff0087's Avatar
huff0087
huff0087 is offline
1952 F6 MH
.060 pistons, .020 rods and mains
  #72
Old 03-26-2012, 10:19 PM
ben73058's Avatar
ben73058
ben73058 is offline
Winston,
That flathead looks like some high school science experiment
gone crazy! I like it! Have you fired it up to see what it sounds
like - I bet it's wild!
Eduardo - Nobody is laughing - your trucks are running! Don't tell me you still have that soda bottle gas tank in there?
Ben in Austin
  #73
Old 03-27-2012, 09:51 AM
Ravenheart's Avatar
Ravenheart
Harrier,
The two liter soda bottle acts as a temp fuel tank, the one under the cab is missing the cap and the hoses are old and stiff. Much easier to add some gas in there and a spit straight to the carb to get her started once a week.
Ben,
Yeap, it's still there. Julie's been parked for over a year now and I haven't started her since July. The flywheel's missing a few teeth and the starter is right on that spot. I've been too lazy to crank the damper pulley with a socket to get it to move from there. Need to do it soon though. Would this be a "running when parked" situation?
I'll be in Utah in the summer, so I think I'll order the rubber grommets at the filler and gas caps for both as soon as I can remember my dad's address.
  #74
Old 03-27-2012, 07:59 PM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
I don't know if you really want to see my engine. I'm tearing it down to freshen it up. It ran okay, but I'm going to fix a few leaks and give it some fresh paint. Anybody know how to get the dipstick to stop seeping? Can the rivets be tightened up, or do I need to remove them and put a new seal under the whatever it's called?
  #75
Old 03-27-2012, 09:18 PM
wilsel's Avatar
wilsel
wilsel is offline
You can't tighten the rivets once they are in. I would drill them out, make a new gasket, and re-rivet since you already have the pan off. Or you could weld it, which would be a permanent fix, and you wouldn't have to worry about a bad seal again.
Quick Reply: Lets see your engine now !
