1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Loss Of Power after going up hill
Old 02-24-2012, 08:32 AM
jthurs311's Avatar
jthurs311
jthurs311 is offline
I am new to post but have been searching for answers. I have a 2003 F250 King Ranch with about 150k miles on it. I am having a problem when i come to a stop at the top of a long steep hill. Once stopped, I try to accelerate and nothing happens. The engine seems to bog down and puts out some black smoke out the tail pipe. This will last for about 20-30 sec and then the engine will pick back up and resume as normal. Keep in mind i am not pulling anything when it happens. I have recently had the EGR Cooler/filter, High pressure oil pump replaced. This particular problem happened a few times prior to getting the Cooler replaced and i took EGR valve out an cleaned it and the problem went away for awhile, but its back again (10k miles ago). Do you all think i just need to replace the EGR Valve or is it something else?
Old 02-27-2012, 01:03 AM
willietwosix's Avatar
willietwosix
willietwosix is offline
super duty engine protection system is your problem
running too hot makes the engine switch 4 cylinders on / off at a time to cool engine
part of the problem might be the vanes on your turbo sticking in a position and too much heat coming back into the engine
easiest way to clean out turbo is to punch it every once and a while with a descent load on truck to push out build up in turbo...
but id say you need an egr delete kit
or just keep replacing the valve
BillC1009
10-07-2020 11:21 AM
Dodsie
10-17-2013 08:07 PM
EddieEX10
05-11-2010 03:52 PM
gearloose1
10-27-2009 08:59 PM
Van Diemen
10-07-2009 09:34 AM
Quick Reply: Loss Of Power after going up hill
