brake problem F53 chassis - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 02-24-2012, 03:20 AM
German Joe German Joe is offline
German Joe is starting off with a positive reputation.
Hi @ all,
Im a new member and I would like to post a question:
I own a 1999 Pace Arrow motorhome by Fleetwood, 35ft, Ford Triton V10 6.8l<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
VIN: 3FCNF53S2XJA32486<o></o>
Im living in germany and the motorhome is just for vacations in the USA. <o></o>
Now I need new brake pads and brake rotor (or disk) for the right rear side. <o></o>
The wheel has 8 bolts.<o></o>
I contacted Ford and they gave me this numbers:<o></o>
The part numbers you need are 8u9z-2001-c for the rear pads and<o></o>
f81z-2c026-aa for the rear rotor.
But I contacted another dealer and he gave me for the rotor the number:
6u9z-2c026-a.
In the meantime I contacted different dealers and some said 6u9z-2c026-a and some said f81z-2c026-aa.
<o></o>
I found a picture in the internet that shows 10 holes in this rotor, but my wheel has only 8 bolts.<o></o>
Is there something between the wheel and the brake disc? Is there a hub between? I cant look at my motorhome, because it is in the USA and I found no picture that shows me the contruction from the brake and axle.<o></o>
I know german car breaks but no american motorhome breaks
Could anybody figure out which rotor is the right one?
I would like to buy the spareparts I need and repair the breaks by myself when Im back in the USA.
Thanks a lot
Joe
Old 02-25-2012, 02:31 AM
The part numbers you need are 8u9z-2001-c for the rear pads and>>
6u9z-2c026-a.
Can anybody help me? Im really confused
Old 02-25-2012, 12:19 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
DO you have single or dual rear wheels?
Old 02-25-2012, 12:24 PM
Quote:
Hi, Ive dual rear wheels
Old 02-25-2012, 03:09 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the Large Truck forum.
Old 02-26-2012, 10:09 AM
80broncoman 80broncoman is offline
80broncoman is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by German Joe View Post
Hi @ all,
........I found a picture in the internet that shows 10 holes in this rotor, but my wheel has only 8 bolts.<o></o>[/SIZE][/B]
[B][SIZE=2]Is there something between the wheel and the brake disc? Is there a hub between? ......
Yes. the holes you see in the rotor are not the holes for the studs that hold the wheel on.
THere is a hub that has both the hole for the rotor and the studs for the wheels.
Old 02-26-2012, 11:42 AM
O yes, thank you! I found a video at youtube where I could see that.
Do you have any idea how I can figure out which part number is the right one?
Old 02-27-2012, 07:45 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Brake problem with F53 chassis / 1999 Pace Arrow Motorhome.
The part numbers you need are 8U9Z-2001-C for the rear pads and F81Z-2C026-AA for the rear rotor.
But I contacted another dealer and he gave me for the rotor the number: 6U9Z-2C026-A
8U9Z-2001-C (replaced F81Z-2001-CA) = 1999/2002 F53 Stripped Chassis / 1999/2002 F450/550.
MSRP: $83.30 // FTE sponsor tousleyfordparts.com price: $54.98.
F81Z-2C026-AA = 1999/2002 F53 Stripped Chassis / 1999/2002 F450/550.
MSRP: $149.97 // FTE sponsor tousleyfordparts.com price: $98.98.
Note: I do not have a Ford truck parts catalog after 2002, the following info came from Tousley's website:
6U9Z-2C026-A (replaced: 1C3Z-2C026-AA) is not listed for an F53, is not listed for anything prior to 2003.
Type (edit) part number 6U9Z-2C026-A into Tousley's website to see all its applications.
Once you've signed on...click on HOME, then type the part number into the box, notice there are 5 pages of applications.
For further assistance, contact Tousley Ford, located in White Bear Lake MN
Edit: There are no applications listed for F81Z-2C026-AA
Last edited by NumberDummy; 02-27-2012 at 04:54 PM. Reason: Post edited to clarify.
Old 02-27-2012, 12:54 PM
Thank you, NumberDummy. I wrote an email to you!
Old 02-27-2012, 04:58 PM
Yes, thank you, I received it...see edited post #8.
Old 02-28-2012, 01:36 AM
You are very helpful, thanks!
E4OD to ZF 5S-42 swap break down myakkacracka Clutch, Transmission, Differential, Axle & Transfer Case 13 06-16-2016 12:33 PM
Changing the upper (secondary) fuel filter in a 6.0L bismic 6.0L Power Stroke Diesel 56 08-10-2015 11:35 AM
E4OD to ZF 5S-42 swap break down myakkacracka 1987 - 1996 F150 & Larger F-Series Trucks 6 03-17-2014 08:35 AM
96 f150 drivetrain restore suggestions closetheborder 1987 - 1996 F150 & Larger F-Series Trucks 1 08-16-2012 12:40 PM
Locked Up Clutch Fan How Mpg Decreases? RENTGEEP 1994.5 - 1997 7.3L Power Stroke Diesel 15 12-22-2008 08:02 PM
Tags
1999, 2006, 2009, 2011, 2012, brakes, chassis, dealer, f53, f81a2c026c, ford, fseries, list, midatlantic, motorhome, recall
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
