1947 1-ton ignition switch schematics
Old 04-27-2013, 04:53 PM
christurney77's Avatar
christurney77
christurney77 is offline
Read 5 Star's post...
https://www.ford-trucks.com/forums/1...n-removal.html
This will give you what you need!!!
Old 04-28-2013, 02:39 AM
Simon G's Avatar
Simon G
Simon G is offline
Thanks! But I'm not sure thats what I meant.
I have got the key cylinder removed but I try to remove the mechanism that the key is working. See picture below..
Any ideas?
/S
Old 04-28-2013, 07:16 AM
newold46's Avatar
newold46
newold46 is offline
From here:
Ford was one of the first car manufacturers to use locking steering wheels. Vehicles from 1932-1948 used this system. The ignition lock is retained by a serrated pin located on the bottom of the steering wheel lock unit. Removal can be done by drilling a hole into the serrated pin and tapping the hole for 6-32 threads. Insert a long screw into the tapped hole, then attach a vise grip to the screw at a right angle. Hold onto the vise grip handle and hit the vise grip near the screw with a hammer, A few swift hits should dislodge the serrated pin. The ignition cylinder can then be removed for key fitting.
Hope that helps some. Mine was missing, so I installed a switch on the dash.
Old 04-29-2013, 12:02 AM
46fordtruck's Avatar
46fordtruck
46fordtruck is online now
Guys, he has the ignition key cylinder removed, its the chrome paddle that you switch on and off to turn the truck off. I've never removed this piece, I have never had to, so I'm not sure exactly how to remove it. Anybody here ever removed the actual chrome paddle switch?
Old 04-29-2013, 08:12 AM
newold46's Avatar
newold46
newold46 is offline
Disregard my post, I didn't see the picture... It looks like the right side is threaded and that will come out. The other part looks like it will have to be drilled. Do they even make that part?
Vincent Delpino
02-25-2012 01:31 PM
Fratzog440
05-28-2011 11:13 PM
jdusten81
04-11-2011 08:08 PM
steetsel
1947 and Older Ford Trucks
01-31-2004 03:58 PM
Franco1961
12-02-2003 04:54 AM
Quick Reply: 1947 1-ton ignition switch schematics
