1947 1-ton ignition switch schematics - Page 2 - Ford Truck Enthusiasts Forums
Old 04-27-2013, 05:53 PM
christurney77's Avatar
christurney77 christurney77 is offline
christurney77 has a good reputation on FTE.christurney77 has a good reputation on FTE.christurney77 has a good reputation on FTE.
Read 5 Star's post...
http://www.ford-trucks.com/forums/12...n-removal.html
This will give you what you need!!!
Old 04-28-2013, 03:39 AM
Simon G's Avatar
Simon G Simon G is offline
Simon G is starting off with a positive reputation.
Thanks! But I'm not sure thats what I meant.
I have got the key cylinder removed but I try to remove the mechanism that the key is working. See picture below..
Any ideas?
/S
Old 04-28-2013, 08:16 AM
newold46's Avatar
newold46 newold46 is online now
newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.
From here:
Ford was one of the first car manufacturers to use locking steering wheels. Vehicles from 1932-1948 used this system. The ignition lock is retained by a serrated pin located on the bottom of the steering wheel lock unit. Removal can be done by drilling a hole into the serrated pin and tapping the hole for 6-32 threads. Insert a long screw into the tapped hole, then attach a vise grip to the screw at a right angle. Hold onto the vise grip handle and hit the vise grip near the screw with a hammer, A few swift hits should dislodge the serrated pin. The ignition cylinder can then be removed for key fitting.
Hope that helps some. Mine was missing, so I installed a switch on the dash.
Old 04-29-2013, 01:02 AM
46fordtruck's Avatar
46fordtruck 46fordtruck is online now
46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.
Guys, he has the ignition key cylinder removed, its the chrome paddle that you switch on and off to turn the truck off. I've never removed this piece, I have never had to, so I'm not sure exactly how to remove it. Anybody here ever removed the actual chrome paddle switch?
Old 04-29-2013, 09:12 AM
newold46's Avatar
Disregard my post, I didn't see the picture... It looks like the right side is threaded and that will come out. The other part looks like it will have to be drilled. Do they even make that part?
1990 F250 Aligning Ignition switch actuator rod BuckHunter1960 1987 - 1996 F150 & Larger F-Series Trucks 3 05-22-2016 04:47 PM
1988 f-250 clutch pedal diagram Natcox012 1987 - 1996 F150 & Larger F-Series Trucks 0 04-05-2015 06:22 PM
ignition switch questions scottlathrop 1961 - 1966 F-100 & Larger F-Series Trucks 2 11-24-2013 08:54 AM
HELP .... Need Ignition Switch Connector Diagram sgtnike 1999 to 2016 Super Duty 0 02-18-2012 04:10 PM
Sticky Ignition Switch BeerKnurd 1961 - 1963 F100 Unibody 0 09-24-2011 03:29 PM
Tags
12, 1947, 1tonne, 23, 65, diagram, diesel, ford, ignition, light, pick, pickup, sd, switch, ton, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
