1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
"lifter" tick.. Cause for concern?
Old 02-23-2012, 08:37 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
Recently my 2000 F350 CC V10 has a pretty noticeable clicking whenever I start the truck when it's cold and you can hear it Im the cab. It comes for the back passenger side of the motor and changes with the rpms. After about 2 min it will suddenly stop and not come back untill the truck sits all night. I run Mobil 1 5-30 and a FL820s filter. I put a mechanical guage on for the oil pressure and it's between 45-47 psi cold at 1100 rpm. I was told it could just be a lifter loosing oil pressure but is this a sign of more trouble like an oil pump? The truck has 159,000 on it and from what I can tell was well taken care of. It'd just got me paranoid because im new to the v10. Any ideas would help or should I just let it be?
Old 02-23-2012, 10:10 PM
Boris2000's Avatar
Boris2000
Boris2000 is offline
Maybe just try changing your brand of oil. You never know, In my HD the Mobil 1 made the lifers clatter more. Just saying!
Old 02-23-2012, 10:17 PM
powerstroker100's Avatar
powerstroker100
powerstroker100 is offline
could be manifold leaking
Old 02-23-2012, 10:23 PM
Eugene373's Avatar
Eugene373
Eugene373 is offline
Or it Could be a Lifter letting down ( ie. week Lifter ) & rebuilds pressure after running few, I've had this happen in the Past on other Engines.
Old 02-23-2012, 10:42 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
The exhaust manifolds leak but this Is more of a harder lifter style. Should I be concerned? Ford said its prolly just a weak lifter and won't hurt anything but I will change brands of oil for the next change or should I change it right away?
Old 02-23-2012, 11:28 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
umm the mod motors are overhead cam.. they dont even have lifters...
your noise is most likely a exhaust leak due to rotted studs..its really common on these motors.
have you checked for rotted studs ?
Old 02-23-2012, 11:32 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
The truck has broken studs. I don't know the exact term but it's what's similar to a lifter I'm guessing. It's a metallic clicking and goes away after a min but I know it's coming from the top end pass side valve cover area. I plan on pulling it this weekend and lookiong for anything out of the ordinary.
Old 02-24-2012, 08:04 AM
Eugene373's Avatar
Eugene373
Thanks Man! wasn't awear of this at all, I'll be checking for broken studs as well as my truck does the same & just figured it was a lifter was all..
" And Knowing is half the Battle "
~Eugene
Old 02-24-2012, 08:37 AM
powerstroker100
if it was me, I would address the manifold leak first, get some grade 8 hex bolts to replace the crap studs or you can find stainless steel studs which are nice
then I would move on to the next thing, plan on doing the manifolds over a weekend and soak them with pb during the week
I've also heard about piston slap on these triton engines which could be what your experiencing? might want to look into that as I don't know a ton about these gas engines
Old 02-24-2012, 08:55 AM
MDSuperDuty's Avatar
MDSuperDuty
MDSuperDuty is offline
When I purchased my truck it made a wierd "metallic" sound and the salesmen (I know most have rocks for brains) said "It's just the Ford lifters." After I signed on the dotted line I set up a service appointment as it was still under warranty. Sure enough bad manifold and rotted studs. Not saying this is your problem but the noise followed the rpms and sounded super weird. And this truck only had 25k on the clock!
Old 02-24-2012, 09:30 AM
Kdr358's Avatar
Kdr358
Kdr358 is offline
I do plan on replacing the studs In the spring or once all this snow melts. I know I have one broken on the driver side but i will post a video later and see if it does it! I just am paranoid after spending 3,500 on the truck.
Old 02-24-2012, 09:32 AM
MDSuperDuty
Im glad mine was warrantied as it gets pricey if you dont do it yourself!! Plus there are a pain to get to I guess. Not trying to be a smart "A" but I guess that spending money on a 12 year truck kinda comes with the territory, right? My winter beater Taurus needs a new oil pan gasket, wheel bearing, and I'm sure I'll find something else. But it keeps my truck out of the salt!!!
Old 02-24-2012, 03:57 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
Could the timing chain tensioning guides or timing chain guides be the problem? I know they were an issue on the 2000-2003 4.6 motors and I'm sure my truck had lots of idle time as well.
Old 02-25-2012, 11:04 AM
fbnmark's Avatar
fbnmark
fbnmark is offline
FYI overhead cams they are called cam followers not lifters
Old 03-01-2012, 06:57 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
Just an update, I replaced the spark plugs today and I noticed that my passenger side valve cover is leaking pretty good enough to leave a few plugs pretty oily as well as the top of the COP boots. Would the valve cover gaskets leaking pretty bad when the truck is cold the rubber dries up I assume this could cause all sorts of oiling problems to the cam and cam followers and cam followers by having the oil leak out?
Quick Reply: "lifter" tick.. Cause for concern?
