390 to 460
Old 02-23-2012, 07:23 PM
amosmoses's Avatar
amosmoses
amosmoses is offline
390 to 460
hey guys i have a 74 f100 with a 390 fe big block in it and im looking a buying a rebuilt 460 for in it. was just wondering if my 4speed trans will bolt up?
Old 02-23-2012, 07:37 PM
wdfp's Avatar
wdfp
wdfp is offline
It should with the right bellhousing, you will need several 460 specific things to put it in there, engine perches either a 460 flywheel or have your 390 flywheel balanced to the 460 if its a 79 or newer block, I've heard its better to get the 460 piece.. But with the right pieces it should bolt in! At least it did when I went the other way, put a 390 in a 79 replacing a 460/ C6 with a 4spd trans, the engine swap was easy, only slightly harder to go from auto to manual. A parts vehicle helps a lot though
Old 02-23-2012, 08:07 PM
amosmoses's Avatar
amosmoses
great thanks. what do you think would be the best way to go about getting the proper bell and flywheel?
Old 02-29-2012, 11:17 AM
amosmoses's Avatar
amosmoses
anybody got a lead on 460 perches, motor mounts, bell housing for a 4speed?
Old 02-29-2012, 04:18 PM
kelsey_kaye's Avatar
kelsey_kaye
kelsey_kaye is offline
alot of people use L&L brand mounts.
Old 03-02-2012, 02:57 AM
77honkey's Avatar
77honkey
77honkey is offline
All kinds of Fe & BBC mounts clutch & bellhousing + miscellaneous 4 sale/swap
Old 03-02-2012, 03:42 AM
ygoldsberry's Avatar
ygoldsberry
ygoldsberry is offline
dont want to hijack your post but i see your in pa whats your plan for the 390 im looking for one (or atleast the rotating asembly)
Old 03-02-2012, 07:05 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
....and I'll buy your bell housing!
Old 03-02-2012, 08:21 AM
thunder74-79's Avatar
thunder74-79
thunder74-79 is offline
i used L&L products towers and mounts in my 74 highboy when i put my 460 in. they sell a kit for these trucks. I am also running their fenderwell headers. LOVE IT!!! lol
As far as the bell housing i am using a lakewood steel housing. you can find used ones for pretty reasonable on racingjunk.com
Old 03-02-2012, 06:48 PM
wdfp's Avatar
wdfp
wdfp is offline
I don't know where you are at but today there is an 84 460 listed in Idaho Falls with a bellhousing still on it on Craigslist for 150.00. I also know of a 460 w/standardtrans and transfer case here just north of idaho falls a little ways, I think its still there anyway and thats all I can think of right now..
Old 03-02-2012, 06:52 PM
Highboy74's Avatar
Highboy74
Highboy74 is offline
Autofab has the best mounts, bar none!
Old 03-02-2012, 07:09 PM
77honkey's Avatar
77honkey
77honkey is offline
What all wrong with yer 390? I got Fe & big blocks thinkin bout goin all Fe
Old 03-02-2012, 11:52 PM
YoungMT Hick's Avatar
YoungMT Hick
YoungMT Hick is offline
I have a 360 in NY I would like to get rid of. I plan to do the same a swap a 460. Mine will be a mud truck so j will just go with DEC upright headers and L&L mounts once I get rid of the 360
Old 03-03-2012, 12:20 AM
77honkey's Avatar
77honkey
77honkey is offline
What intake & distributer?
Old 03-03-2012, 11:59 AM
YoungMT Hick
PM Sent . . . .
johncart
40
09-29-2008 12:05 AM
kyleshelley
15
03-21-2004 08:29 PM
460429_freak
01-02-2003 10:33 AM
69 F100 4x4
01-23-2002 10:48 AM
yakimakanutt
01-12-2002 08:16 PM
Quick Reply: 390 to 460
