ford 434 stroker - Ford Truck Enthusiasts Forums
ford 434 stroker
Old 02-23-2012, 07:01 PM
1979fordf150rebel 1979fordf150rebel is offline
1979fordf150rebel is starting off with a positive reputation.
ford 434 stroker
Should I build my 351m into a 434 stroker or just mildly build my 351m
Old 02-23-2012, 07:18 PM
YZ250rider YZ250rider is offline
YZ250rider is starting off with a positive reputation.
If you have the money 434 it!
Old 02-23-2012, 07:23 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is online now
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
I would stroke out a 460 if I were you.
Old 02-23-2012, 07:27 PM
How much would I run to build the 434 stroker and what all is needed and I don't really wanna do a 460 for the fact that I'm limited on headers and mounts and all that
Old 02-23-2012, 07:36 PM
Buck0's Avatar
Buck0 Buck0 is offline
Buck0 is starting off with a positive reputation.
Give Tim Meyer a call. He can tell you all you need to know. Then please post some info because someday when I have some cash I would like to do this as well.
Old 02-23-2012, 07:53 PM
jmm's Avatar
jmm jmm is offline
jmm is starting off with a positive reputation.
the stroker kit from tim is 2,300 plus heads, at 1800 bare plus any other parts and machine work id guess closer to 6k but you should be pushing 500hp. dollar for dollar a 460 is cheaper to build. Parts are cheaper and more plentiful to get a hold of.
if you wanted you could mild build your 351, all u have to do is change the 351 crank to a 400 crank and you got a 400. bore .030 headers, cam and 4 barrel, and you got a pretty mean engine.
depends on what your into and how deep your pockets are.
Old 02-23-2012, 07:55 PM
Behemoth Behemoth is offline
Behemoth has a great reputation on FTE.Behemoth has a great reputation on FTE.Behemoth has a great reputation on FTE.Behemoth has a great reputation on FTE.Behemoth has a great reputation on FTE.Behemoth has a great reputation on FTE.
I'm sure Tim could guide you toward a more budget version of the 434 than how we did it with mine. I kinda went overboard and got all the shiny doo-dads on top of the machine work and stroker kit, so it cost considerably more than what one might think of as a "budget build". If you have a machine shop you trust, and you get the right parts from Tim, I'm sure you could keep some of the cost down.
Old 02-23-2012, 08:01 PM
jmm's Avatar
jmm jmm is offline
bohemith did you pay north of 6k?
Old 02-23-2012, 09:56 PM
Yup, you could say that.
Old 02-23-2012, 11:36 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Why polish a turd?
Dollar for dollar, a 460 is waaaaaay better value than the weak-kneed 351M stroker.
Old 02-24-2012, 04:18 PM
Yes but I wanna build the underdog motor for the fact my truck is an underdog and so am I so I wanna build a poor motor and bore and stroke it
Old 02-24-2012, 04:54 PM
MyName1sMud's Avatar
MyName1sMud MyName1sMud is offline
MyName1sMud is gaining momentum as a positive member of FTE.
To each his own....
i'm switching to a 460 when i got the cash.
Old 02-24-2012, 08:17 PM
Quote:
I agree with you. Plus I like too be different from all my buddys they have diesels and 460s. I like too see them get pissed when the wussy a** 400 beats them makes my day.
Old 02-24-2012, 08:30 PM
There goes Silver again, just making friends everywhere he goes.
If the man wants to build a 351m into a 434, then that's what he should do. Yes, we get it.....the 460 is bigger, and cheaper to get HP out of after about 450hp (up to that point, they're pretty much the same cost wise). The issue is that he wasn't asking about a 460. He probably already knows that's an option, but like me, wanted to go the path less traveled. Then again, maybe he already knows that John Kaase has been winning the Engine Masters Buildoff with the 335 engine block for a few years now, and wanted to do something with that platform.
I would say, however, that if he wants to keep the cost down, maybe a healthy 400 would be more palatable. Like Jmm said, you could swap the crank and rods, and do a fair 400 build pretty cheap, which would yield over 400hp easily. Again, I'm sure if you ask Tim Meyer, he could give you lots of options to think about.
I just went the 434 route because I didn't want to be a sheep, and do what everyone else does. I've had 460's, and I like them. If power was my only concern, then yes, I'd probably build a beast 460 for a lot cheaper than a healthy 434. The difference is that I wanted to try something a little different......which is maybe the point Rebel was trying to make in the first place.
Old 02-24-2012, 10:43 PM
HIO Silver's Avatar
OK. Point made.
434+ build T_Cooksey88 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 08-07-2015 10:57 PM
Help with build T_Cooksey88 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-16-2015 02:56 PM
Lockers...want or need? apachetech 1973 - 1979 F-100 & Larger F-Series Trucks 16 04-30-2015 08:20 PM
Headers 79 F250 4x4 NP435 apachetech 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-16-2015 07:31 PM
393 stroker compression ??? Brian460 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 01-07-2003 12:31 PM
Tags
1979, 250, 400m, 434, block, cost, fe, ford, kits, mid, ohc, stoker, stroker, tmeyer, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
