where to buy oil cooler o'ring kit? - Ford Truck Enthusiasts Forums
Old 02-23-2012, 05:23 PM
mudguts mudguts is offline
mudguts is starting off with a positive reputation.
I'm looking to buy a rebuild kit o'rings and gaskets, I checked rock auto and no luck, napa, and auto zone, when I was in town last time,(100 miles one way) hopefully somebody will know where I can look, Thank's MudGuts.
Old 02-23-2012, 05:24 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
dieselorings.com ?
Old 02-23-2012, 06:33 PM
Thank's MudGuts.
Old 02-23-2012, 07:17 PM
typefour's Avatar
typefour typefour is offline
typefour is starting off with a positive reputation.
I have kits for that from uhaul surplus on hand 45.00 shipped
Old 02-24-2012, 07:36 AM
Good how do I get ahold of you? Thanks MudGuts
Old 02-24-2012, 07:42 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Quote:
send a private message
Old 02-24-2012, 11:16 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
Victor Reinz now has the Oil Cooler O-Rings ...
Oil Cooler O-Rings ... Victor Reinz PN: GS33545 at RockAuto for $6.34.
Oil Cooler Gaskets ... FEL-PRO PN: ES70689 at RockAuto for $3.25
Thanks to me and another FTE member!
-Enjoy
fh : )_~
Old 02-24-2012, 01:22 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
Ford always has these on hand....they are 32.00 bucks and you can walk out with them....
Old 02-24-2012, 06:25 PM
Mikey Oldaker's Avatar
Mikey Oldaker Mikey Oldaker is offline
Mikey Oldaker is starting off with a positive reputation.
Engine Components Ford 6.9L 7.3L IDI
i was just messing around and found this thought it might be helpfull?
Old 02-25-2012, 01:52 AM
jaluhn jaluhn is offline
jaluhn is starting off with a positive reputation.
Or the IH dealer. They're usually cheaper. Remember there's 2 sizes, you need 2 of each. Gaskets are different between the truck, van and IH apps too, make sure you get the right ones.
Old 02-25-2012, 12:39 PM
Aune163rd's Avatar
Thats a good price on the O-Rings....
Old 02-25-2012, 12:40 PM
Aune163rd's Avatar
I would definitly NOT want to buy the oil cooler assembly new XD!
Old 02-25-2012, 02:23 PM
typefour's Avatar
do not use any type of silicone or other sealer on the gaskets, use high tack spray to glue them solidly to the headers nothing against the block, but if you must a VERY light as in see through coat of aviation permatex or indian head gasket sealer. any rtv will be a lubricant and split the gaskets, also do not overtorque.
the rock auto orings used to be a pain to get to slip in , so be sure the header is square with the bundle and it will push on by hand.
Old 02-25-2012, 02:25 PM
typefour's Avatar
Quote:
maybe in montana, gaskets also, ?
Thats why I bought all the uhaul ones when they came up, oem IH and they came with the right gaskets , which look like felpro made them, exactly the same.
Old 02-26-2012, 12:43 AM
I'd be worried about the quality of cheap O-rings too.... as much of a PIA as it is to do the job it's just not worth the risk to me. And if they do leak you'll be spending a ton of money on oil and coolant and trying to flush the lube and cooling systems. Been there, done that.... not fun.
Also, putting the new rings in requires care and patience. Put the O-rings on the tube bundle, not in the end caps. One of the service manuals out there tells you to put the small O-rings in the end caps and then try to assemble it... it doesn't work. Learned that one the hard way. Putting both on the bundle seems to work well and make sure to use plenty of lube too.
I've also seen a hydro jib made up for these using a chunk on steel drilled for the bolts and ports and an air fitting on one of the ports. You bolt the new cooler on, fill one side of it with water and pressurize the other with air... Leaks will show as bubbles. I can't remember the exact details, but it seemed pretty easy to set up and for sure worth it.
injector oring size Nathan Cox 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-05-2016 10:54 AM
Fuse box 1985 F-250 6.9 Where to buy one mudguts Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 05-21-2016 05:52 AM
connecting rods mudguts Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 11-05-2012 09:00 PM
BIO Diesel mudguts Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-11-2012 06:56 PM
o-rings for my hubs blrman1962 1999 - 2003 7.3L Power Stroke Diesel 2 03-27-2011 11:57 AM
Tags
73, 96, 99, buy, cooler, engine, f350, felpro, ford, gasket, gs33545, kit, oil, oilcooler, rings, seal, whear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
