2001 escape v6 PS pump replacement
ok so something is in my way, and i believe it is called the "engine insulator". Write up on replacement I am using indicated the engine must be supported to remove this? reccemmends a 3 bar "from top" support that is way more expense than i'm willing to shell out on this repair. does it really need to be supported when i pull that? if it does whats the best way to do it with a jack from underneath? Or does anyone have a good write up on PS pump replacement for 2001 escape v6?
ml_nelson
10-28-2013 08:09 AM
