66 w/ swapped in 390 want manual tranny
I have a 66 f100 stepside with a 390 and a c6. I would like to swap in a manual transmission as it originally came with a manual and the pedal is still there. Any suggestions on a 4 or 5 speed that is a good mate to the 390 would be a great help. I am not real familiar with the 390 or its transmission options. Planning to keep the 390 mild.
Thanks to all!
Thanks to all!
Will most of your driving be over 60mph without a trailer or load in the box?
If so, then a transmission with an overdrive final drive gear is what you'll likely want. A mid-80s RTS (T170FT) transmission would fit that requirement.
If you do plan to work the truck, then a T-18 or a NP435 transmission without an overdrive final drive gear would likely suit you better.
Just MHO, -- BarnieTrk
Rusty_Old_F250
29
05-01-2011 10:58 AM
Michael Sizemore
06-15-2005 04:20 PM
tsv1961Ford
01-31-2004 07:56 AM
Smooth_One
04-10-2003 11:09 AM
