Super GTP or 38R
Old 02-22-2012, 04:46 PM
japaleno's Avatar
japaleno
japaleno is offline
Super GTP or 38R
Is there a preference out there between these two tubos?
Old 02-22-2012, 06:01 PM
bulla's Avatar
bulla
bulla is offline
Can you give us a link to the "super gtp"?
Old 02-22-2012, 06:25 PM
cps's Avatar
cps
cps is offline
PDRdiesel.com. I have the GTP and it works great.It does have .84 exhaust housing so i am not sure of what the differance would be as compared to a 1.0 housing. someone will probably chime in on that. The good thing is it is rebuildable.
Old 02-22-2012, 06:28 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
Looks like a stocker with a ported compressor housing to me.
Old 02-22-2012, 06:33 PM
japaleno's Avatar
japaleno
japaleno is offline
Is that good, bad, indifferent?... sorry for my ignorance
Old 02-22-2012, 06:45 PM
BigAlsPSD's Avatar
BigAlsPSD
Really not the same category, but if you want to compare them,
Price: for a few hundred more you could get a 38R Riffraff Diesel: Garrett GTP38R PowerMax Ball Bearing Turbo Which will flow more air, lower EGT's and overall be a quicker, free-er flowing turbo.
Stock turbo with a compressor housing is will be a little better, specs I've seen say 13% increase in flow, so you could just install a ported housing on your stocker and have a super Riffraff Diesel: ATS Ported Compressor Housing or USA Ported Compressor Housing
Really just depends on what you want in the long run, HP goals and such. I also could be wrong about the "Super GTP"
Old 02-22-2012, 06:46 PM
cps's Avatar
cps
cps is offline
PDR had the turbo made for them from ADP Distributers.
Old 02-22-2012, 08:16 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Be the first on here and try it out. We would all like to here. But the 38R has a bigger compressor wheel if I'm not mistaken. If it the same as the 38R without the ball bearing we would all like to here how it preforms.
Chet
Old 02-22-2012, 08:26 PM
bulla's Avatar
bulla
bulla is offline
How much was it?
Old 02-22-2012, 08:40 PM
BigAlsPSD's Avatar
BigAlsPSD
Originally Posted by bulla
How much was it?
Site listed it at $950.00
Old 02-22-2012, 09:13 PM
bulla's Avatar
bulla
bulla is offline
Then I'd bet all it is is a rebuilt stocker with a housing. If you were to spend that kind of money for a couple hundred more you could have the 38r. Way better than stock! Why were you looking at these 2? Are you wanting to upgrade or are you in need of a turbo?
Old 02-23-2012, 12:42 PM
cps's Avatar
cps
cps is offline
A little more info about the GTP. It is not a rebuilt stocker. It is made by ADP distributers for PDR, to their specs to what they wanted. It does have a bigger compressor wheel(not sure how much).It is rebuildable.Does the 38R spool faster, for sure, but it is over $400 more. I guess it really depends on what you want to do down the road. If you want to go north of 400hp then maybe the 38R is the way to go. I have the GTP and it spools fast but having never driven a truck with a 38R i have no comparison. i do not have EGT issues any more since upgrading and have no surging problems. It pulls good now and i am happy with it, now i need a DP tuner.
Old 02-23-2012, 08:11 PM
japaleno's Avatar
japaleno
japaleno is offline
I'm considering an upgrade. I have 160k on the stock turbo and saw mention of the GTP and was wondering about it. I would prefer to have my choice made before mine goes.
Old 02-23-2012, 08:15 PM
BigAlsPSD's Avatar
BigAlsPSD
The turbo in your truck is a Garret GTP38, it is rebuildable as it is now, in case you were not aware.
Old 02-24-2012, 09:33 AM
japaleno's Avatar
japaleno
japaleno is offline
Is it generally recommended to rebuild the stock turbo or replace it with say a 38R? I've seen a 38R for $1299. What would it cost to rebuild?
Thanks for everyone's input!
Quick Reply: Super GTP or 38R
