Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 02-22-2012, 04:12 PM
srqlandy's Avatar
srqlandy srqlandy is offline
1985 Ford F-250
srqlandy is starting off with a positive reputation.
Speedo not working....
My 85 F-250 6.9 IDI with Automatic and 4x4 speedo is not working. I have pulled the cable out of the transfer case and attached it to a drill, and it spins. I think it is missing a part like a gear in transfer case. what should this part look like and does anyone have first hand experience with find the replacement gears?
  #2 (permalink)
Old 02-22-2012, 07:39 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
I am assuming you had someone looking at the speedo and it worked with the drill? If so, the next thing to do is leave the cable off the transfer case, and pull the retaining bolt out and pull the whole housing piece out that the cable threads to. You should have a plastic gear on the end of this.
If the plastic gear looks good, you then need to take the driveshaft off, and then take the snout off on the rear of the transfer case. You will then see a worm gear on the output shaft, if it's even there.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 03-03-2012, 04:50 PM
srqlandy's Avatar
1985 Ford F-250
Alright,
I pulled the entire assembly out of the transfer case and no plastic gear at all. I felt around inside to see if it was right there and it as not. What size do I order as I understand there are several different sizes or splines. I do have the information off of the data tag from the back of the transfer case.
  #4 (permalink)
Old 03-03-2012, 09:06 PM
Franklin2's Avatar
1989 Ford F-250
I am not sure on that. Do a search in this forum(or google works also) for "speedo gear" or something like that, and see if one of the old threads comes up. I remember a couple of guys asking about this, and some others had part numbers and gear colors.
What gear are you missing by the way? The one that hooks to the cable or the one that slips on the shaft, or both?
__________________
Dave F
  #5 (permalink)
Old 03-03-2012, 10:00 PM
srqlandy's Avatar
1985 Ford F-250
I am missing the one that goes on to the end of the speed ometer cable itself. I can feel inside the transfer case and feel teeth that a gear should mate to.
  #6 (permalink)
Old 03-03-2012, 10:11 PM
lavatan's Avatar
lavatan lavatan is offline
1985 Ford F-350
lavatan is gaining momentum as a positive member of FTE.
You can find these gears pretty much anywhere. There are even calculators that will tell you what size (number of teeth) you need. You will need the number of teeth on the drive gear, tire size and diff ratio. Then you'll have to be sure to get the one's for an automatic as they differ from a manual driven gear (left slant vs right slant).
Here is an example:
Ford Mustang AOD 19 Tooth Speedo meter Gear 3.27 2.73 | eBay
Here are some from Jegs:
TCI Ford Speedometer Gears - JEGS
And here is a calculator:
Speedometer Gear Calculator
__________________
Jeremy
1985 F350 Crew Cab, 460ci bored over .030
Dual energy 255DEH COMP Cams cam shaft with matching springs and lifters (Part 34-223-4)
Borg Warner T-19 transmission 3-speed with granny gear
Edelbrock Performer 1406
Last edited by lavatan; 03-03-2012 at 10:13 PM. Reason: Linked manual gear instead of automatic
  #7 (permalink)
Old 03-04-2012, 01:37 AM
kedwinh's Avatar
kedwinh kedwinh is offline
1985 Ford F-150
kedwinh is gaining momentum as a positive member of FTE.
They have the gears for $6 each and the "C" clip for $1 at Jeff's Bronco Graveyard.
Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale
Just got some from them and shipping was pretty fast.
I think they're even still available from Ford.
Tags
150, 2008, 250, ford, idi, speedo, speedometer, stopped, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
