Go Back   Ford Truck Enthusiasts Forums > General > General Automotive Discussion
Sign in using an external account
Register Forgot Password?
General Automotive Discussion SPONSORED BY:
  #1 (permalink)
Old 02-22-2012, 03:21 PM
tjc transport's Avatar
tjc transport tjc transport is offline
Garage is empty, add now
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
01 2.0L dead cylinder.
one of the neighborhood kids asked me for help today with his girls car.
01 Escort, 2.0L. it has a dead cylinder, with cylinder #3 misfire code.
new cap, rotor, wires plugs, because it has 118,000 miles on it and the last tuneup was done about 40k ago. then the car sat for 4 months because it still has the dead hole.
i did a compression check, and have 175 lbs on all 4 holes, put air to the cylinders through the plug holes(about 80 lbs) looking for a burnt/bent valve, and i can hear no leaks through the intake or exhaust. .
when i put the battery to it and fired it up, it fired on all for for about a minute, then i shut it off to put the valve cover on. put it together and fired it, and it is back to 3 cylinders with sucking through the exhaust when the dead hole hits.
no popping through either the exhaust or intake at higher revs to indicate a worn cam lobe either.
i am a bit lost when it comes to these newer engines. anyone have any ideas?
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
SnowBunny for President in 2012
BabyBunny for Vice President in 2012
  #2 (permalink)
Old 02-22-2012, 03:39 PM
Lazy K Lazy K is offline
Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.
Good one. When running on 3 did you check for spark at the dead cyl plug? Did you check for excessive side play in the distributor shaft?
Maybe need a real time data enabled scanner on it to see what is happening.
  #3 (permalink)
Old 02-22-2012, 03:50 PM
no, not yet. i did not have the laptop with me so i could not use the auto enginuity.
i used the autoXray scanner and everything with that checked out ok. with the exception of no codes because it sat so long with a dead battery.
i will try plugging it in to the laptop tomorrow, and put the spark plug adapter on it to check for spark between the wire and plug.
__________________
Tom
  #4 (permalink)
Old 02-22-2012, 07:30 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
1969 Ford F-250
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
I have seen Ford injector connectors break, so make sure that it's actually clipped on tight. If there's any doubt, use a zip tie to hold it tight to the injector.
__________________
Jared
Real trucks have the key on the left
FTE Guidelines
  #5 (permalink)
Old 02-22-2012, 08:00 PM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 has a very good reputation on FTE.55 f350 has a very good reputation on FTE.55 f350 has a very good reputation on FTE.
maybe a broken wire in the injector harness ??? my ih straight truck had this issue every once in a while and it was a broken wire ......... maybe a bad coil on that plug too ??? i'd imagine they act much like the coils i'm used to on all my old stuff , and they get hot and go kaput , but it cools down it works again till once again a little heat ?????????
__________________
that's because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { don't } know especially to newcomers. were on a mission to impress you and make you believe we are all knowing ! yes i am slightly left of center and i am bent on world conquest !!!!!!!! P.A.D.D = project attention deficit disorder . everyone on here has it , and is an enabler !!!! so enter at your own risk !!!!!!!!!!!
  #6 (permalink)
Old 02-23-2012, 07:00 AM
Quote:
Quote:
i actually thought of a bad injector at around 2 am. i am going to do a buzz test on it later to rule out injectors.
this engine still has a distributor, not COP technology.
__________________
Tom
  #7 (permalink)
Old 03-05-2012, 12:27 PM
well, i am still at a loss. it fired up and ran on all 4 for 1/2 hour today. then lost a cylinder again. let it sit for 20 minutes and back to all 4.
i am going to let it sit for a while and swap injectors and see if it follows the injector or stays at #4.
at this point, i am thinking it may be an overheating ECM.
the other head scratcher is excessive vacuum to the PCV valve. if it is in the valve cover, it will collapse the line. if the PCV is out, it is fine. the line from the valve cover to the air box is not clogged, so this is another one cornfusing me.
__________________
Tom
  #8 (permalink)
Old 03-05-2012, 07:59 PM
Ford_Six's Avatar
1969 Ford F-250
It's probably a degraded PCV hose rather than excessive vacuum. It's going to get manifold vacuum regardless.
__________________
Jared
FTE Guidelines
  #9 (permalink)
Old 03-06-2012, 07:48 AM
put a new hose on it, and it still collapses if put in the valve cover.
__________________
Tom
  #10 (permalink)
Old 03-06-2012, 05:44 PM
Phinxter's Avatar
Phinxter Phinxter is offline
1992 Ford Ranger
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
I've had a couple cars with a similar problem, though not Fords. I found leaking intake gaskets, it would either start and run like poop or would start and run fine until it got hot then run like poop. When it is acting up try spraying carb cleaner around the intake gasket and see if it changes.
__________________
Phinxter "Have you ever worked on a Caddy?"
1992 Ford Ranger Danger 3.0 5spd 4X2
1993 Plymouth Sundance (Member of the Allpar 200k club)
2009 Saturn Aura
Tags
1993, 2003, 25di, 30, 40, ceninder, cylinder, dead, engine, ford, ranger, running, sport, trac, transit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
