Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 02-22-2012, 01:36 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is offline
Garage is empty, add now
1972RedNeck is starting off with a positive reputation.
Ignition Timing
What should I set the ignition timing at on a '74 360? It's supposed to be 8* stock, correct? I have it at 12* and was wondering if there would be any gains if I went higher?
Also I run my stock 352 in my '66 at 12*. Would I gain anything more on if I went higher on it? It will outrun the 360 a fair bit the way it is.
__________________
1972 GMC K2500 Factory Air, 383, 700R4, Dana 60, Posi, 4" Lift
1966 F250 4X4 352, np435
1964 F100, 262 I6
"If you cant fix it with a hammer, you've got an electrical problem."
"If it ain't broke, fix it till it is."
  #2 (permalink)
Old 02-22-2012, 02:06 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is gaining momentum as a positive member of FTE.Freightrain is gaining momentum as a positive member of FTE.
It will help only til it starts to detonate(knock). Might be fine til you put something in the bed and have to lug it a bit and then it will rattle it's brains out.
__________________
*signature delete option*
  #3 (permalink)
Old 02-22-2012, 02:24 PM
montana_highboy's Avatar
montana_highboy montana_highboy is online now
montana_highboy has a very good reputation on FTE.montana_highboy has a very good reputation on FTE.montana_highboy has a very good reputation on FTE.
My FE seems happiest at 12* initial (26* mechanical for 38* total).
  #4 (permalink)
Old 02-22-2012, 06:50 PM
Quote:
Before my dad rebuilt a 390 for his truck, he could put the timing at 20* and it wouldn't ping. Isn't this too high?
Also, did the 360's have a retarded timing set like the 400's did?
__________________
1964 F100, 262 I6
  #5 (permalink)
Old 02-22-2012, 11:30 PM
puttster puttster is offline
puttster is starting off with a positive reputation.
Seems like 20 degrees initial would make starting a challenge but could be okay for high rpms.
puttster
  #6 (permalink)
Old 02-22-2012, 11:34 PM
Old Brown F250 Old Brown F250 is offline
Old Brown F250 is starting off with a positive reputation.
Total timing is more important. On a FE, 38 to 40 degrees of total advance (initial + mechanical) are reasonable. As long as the engine does not knock.
Disable the vacuum advance. Rev the motor up until the timing stops advancing, hold it there and then advance/retard the distributor to set the total timing, say 38 degrees. Make sure it is not knocking. The initial timing will end up the difference of the total timing you set minus the mechanical advance of the distributor.
If you want more initial advance, then you will have to be able to adjust the mechanical advance in the distributor to keep total timing in the 38 to 40 degree range. Or whatever advance your engine can hold without knocking.
  #7 (permalink)
Old 02-23-2012, 07:05 AM
I will do this.
Would there be any gains to swap the timing set out for a new one or were the originals straight up?
__________________
1964 F100, 262 I6
  #8 (permalink)
Old 02-23-2012, 10:28 AM
when I opened up the cover the chain on my 352 looked like my old Schwinn bicycle chain. I'll replace it but not sure what the slack in the old one was screwing up, if anything.
puttster
  #9 (permalink)
Old 02-23-2012, 10:54 AM
Quote:
Originally Posted by 1972RedNeck View Post
I will do this.
Should be okay for a stock engine. Also, points are reliable but are not as efficient as electronic ignition.
Keep in mind, advancing the initial timing will gain some power, up to a point. Beyond that point you will start to loose power. By manually adjusting the timing you are trying to improve the efficiency of the ignition system.
  #10 (permalink)
Old 02-23-2012, 05:16 PM
The 360 has electronic ignition. The 352 is point type. I have a dual point distributer for an FE. Would there be any gains to swap it into my 352?
__________________
1964 F100, 262 I6
  #11 (permalink)
Old 02-24-2012, 07:31 AM
Marky48170's Avatar
Marky48170 Marky48170 is offline
65 f250, 67 f100, 76 f250
Marky48170 is starting off with a positive reputation.
My 65 w/352 got set to 24 initial time because of a loose dizzy bolt, it started fine and idled fine but going down the road it made a Shhhhhhhing sound and acceleration just wasn't there. When I checked the timing it was set @ 24 btdc so I set it back to 12 and it runs great. So I'd start with 12 and go from there.
__________________
1965 F250 CS 352 NP435 4 Spd Dana 60 w/4:10
1967 F100 302
2002 Ford Explorer Sport
2010 Ford Flex
  #12 (permalink)
Old 02-24-2012, 04:34 PM
travelerest travelerest is offline
travelerest is starting off with a positive reputation.
The first thing you want to do is make sure your timing chain and gears are good. Then set your total timing at a maximum of 38 degrees when using regular gas. Get rid of the points and go to a petronix electronic setup.
Click on the below.
Ignitor
  #13 (permalink)
Old 02-24-2012, 06:24 PM
Will there really be that much gain getting rid of points?
__________________
1964 F100, 262 I6
  #14 (permalink)
Old 02-24-2012, 06:26 PM
Argess's Avatar
Argess Argess is offline
Argess is gaining momentum as a positive member of FTE.
Quote:
Click on the below.
Ignitor
I agree, and the Balancer must be accurate too. The Pertronix Ignitor was the best thing I ever did for my engine. Cheap too, although I did have to get the Pertronix matching coil (didn't have to until I bumped my CR from 9.5 to10).
My FE isn't in a truck, but in a 2500 lb kit car, so things can be different. Plus I have Crane Fireball cam installed. But I had a bog that I couldn't get rid of through idle stop setting, idle mixture setting, or accelerator pump tuning. I finally started playing with timing and found 20 deg BTDC at 850 rpm worked great. Springs were light so it cranked at 15 deg BTDC. But always, I kept the max advance at 38 deg BTDC by adjusting the distributor internals.
Now perhaps I should have kept playing with the carbs, but the timing worked and those figures arn't unique; they have worked for others. (Oh, I forgot to mention; I don't use a vacuum advance distributor).
I've mentioned all this to show what a variety of intial timing settings will work, yet always keep that 38 deg total in mind. It can vary too (and if so, generally lower, not higher), but it's a good rule until you get things fine tuned.
But if you are stock, or close to stock, start with the factory specs and even after fine tuning, you shouldn't be very far away from that. If the stock settings are suspect, then do as suggested and set the timing for 38 (or 36 to be safe) max advance, and then see where it is at idle. From then on, you can use that idle reading when doing a tune-up.
Of course, with a Pertronix unit, you won't need to fix the timing during a tune-up!!! Well, it's rare...
  #15 (permalink)
Old 02-24-2012, 09:46 PM
MeanGene427 MeanGene427 is offline
MeanGene427 is gaining momentum as a positive member of FTE.
Just in case you happen to go to a Pertronix, the coil choice has nothing to do with compression ratio, and you don't necessarily need a different coil, it depends on how your vehicle is wired & equipped, primary resistance wire, ballast resistor, full 12v etc. Read the directions from Pertronix carefully and use what they tell you and you shouldn't have a problem, but if you run the wrong setup it can cook pretty quick. One great application for a Pertronix is if you have a distributor that's sloppy and eats points, you can put an Ignitor in there and it will start like new. We put one in an old C800 with a 391HD governor distributor with a worn-out dizzy and it pops off like a new truck now
Tags
1972, 1997, 352, 360, 400m, 427, 429, 65, 700, advance, distrubutor, fe, ford, ignition, set, timing, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
