Door speaker size in a 92 f150 regular cab xlt flare side - Ford Truck Enthusiasts Forums
Old 02-22-2012, 02:07 PM
MikeBailey77 MikeBailey77 is offline
MikeBailey77 is starting off with a positive reputation.
what is the size of the door speakers in a 92 reg cab xlt? I am looking to change them so the don't sound like a transistor radio. Also if possible what size are the rear cab speakers?
Old 02-22-2012, 02:46 PM
nflfreak43's Avatar
nflfreak43 nflfreak43 is offline
nflfreak43 has a good reputation on FTE.nflfreak43 has a good reputation on FTE.
doors are 6 1/2".... rear cab's are 6x9......
Old 02-22-2012, 04:55 PM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
Stock Rears are 5"x8" but 6x9 fit
Old 02-22-2012, 06:17 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
Stock door speakers are 5 1/2" round
Rears are 5 1/2' x 7 1/2"
Old 02-24-2012, 01:14 PM
REAPER4206969 REAPER4206969 is offline
REAPER4206969 is starting off with a positive reputation.
I just installed speakers marked 6 1/2"-6 3/4" and there was still about 1/8" of play.
You should be able to install any speaker near that size with no problem.
Old 02-24-2012, 01:36 PM
whiteboyslo's Avatar
whiteboyslo whiteboyslo is offline
whiteboyslo is gaining momentum as a positive member of FTE.
6.5" is what I used. I just did this in my 91 last weekend and I'm almost positive the speaker size stayed the same for the next gen body. Unless they added additional speakers with the body change, the door speakers are all you have if you have a regular cab.
The only issue I had was that the mounting holes in the speakers didn't all line up with the existing holes in the door (2 would, 2 wouldn't no matter how I clocked it), but a couple seconds with a drill took care of that. I drilled the door, not the speaker, btw.
To make life REALLY easy on yourself, pick up a set of these:
Metra Part # 72-5512 | Ford wire harness | Metra Online
They click into the stock speaker harness and keep you from having to clip off the stock harnesses (you know, in case you ever want to install those LOVELY OEM speakers back in). The REAL advantage is that it quickly gives you a couple more inches of speaker wire to mess with. You'll find that Ford was none too generous with extra slack in the speaker wire, so these help a LOT. Not necessary, but I really like them. If you get lucky, the terminals at the other end will slide onto the connections on your new speakers. I didn't have this luck with the Pioneers I installed, but all I had to do was cut off those terminals and crimp on the wires that came with the speakers. Easy as pie.
It should be noted that these are what I used on my 91. I would assume, based on Metra's description, that the 92 would use the same style connector, but if not, I'm sure they make one for your application.
Mike
Old 05-12-2015, 12:41 PM
bsimpson_88 bsimpson_88 is offline
bsimpson_88 is starting off with a positive reputation.
Would the speaker size be the same for a 1992 f150 reg cab long box 2 wheel drive? Looking to do the speakers in my truck as well.
Old 05-12-2015, 01:39 PM
GoFastGuy GoFastGuy is offline
GoFastGuy is starting off with a positive reputation.
Quote:
Yes door speakers stayed 6.5, and check to see if you have rear cab speakers, in the single cabs I've heard of some people having rear speakers and some not in the single cab, my 93 and my 94 both have rear speakers and there both single cabs.
speaker size curtainrod 1987 - 1996 F150 & Larger F-Series Trucks 5 08-11-2014 04:49 PM
Speaker replacement jake_c_19 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 12-15-2013 10:13 AM
2012 Super Duty - quick question - speaker size troverman Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 06-05-2013 04:23 PM
Speaker size? 93 mix 'n match 1997 - 2003 F150 6 02-16-2010 08:38 PM
Speaker Sizes pmasley Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 9 01-21-2006 01:14 PM
Tags
01, 1994, 1995, 73, 92, cab, door, f150, ford, kicker, power, regular, single, size, spakers, speaker, speakers, stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
