GEM module - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
GEM module
Old 04-24-2003, 04:44 PM
blow blow is offline
blow is starting off with a positive reputation.
Angry GEM module
Recently bought a 2000 EB Expedition, a couple weeks ago the defroster started coming on in the middle of the night and other goofy electrical problems. The other day the battery was dead, I got it jump started and noticed a noise like relays chattering away under the dash on the drivers side. Brought it back to the dealer and he said that the GEM module was corroded and needed to be replaced. Is this a common occurence ? Any body else had this happen to them? Thanks.
Old 04-24-2003, 09:15 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
GEM module
Hi blow,
If you do a search on here you'll find that that is quite a common problem. It is usually caused by a leaky windshield. Dont replace the GEM until the windsheild is resealed or you'll probably end up doing it again
Old 07-14-2003, 09:22 AM
mountainman101 mountainman101 is offline
mountainman101 is starting off with a positive reputation.
GEM module
where is that module i had my ac fan on all night
Old 07-14-2003, 10:11 AM
Racerguy's Avatar
GEM module
The GEM is bolted to the back of the fuse box.
Sometimes though the fuse box gets water in it and causes the same problems too.
Old 07-14-2003, 03:17 PM
00Expo&73Bronco 00Expo&73Bronco is offline
00Expo&73Bronco is starting off with a positive reputation.
GEM module
Been there done that too with my 2000. Repair place insisted that their was not a leak and everything was dry up there behind the dash.
Old 05-04-2006, 10:09 PM
stardust stardust is offline
stardust is starting off with a positive reputation.
GEM module/fuse box
I had this same problem, but my wipers wouldn't work at times while it was raining. I did some research & found that a lot of expedition owners have this problem.
Old 05-05-2006, 06:46 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
... Welcome to Ford Truck Enthusiasts!
This happens to be an old thread, however stick around and someone will be by to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 05-05-2006, 10:31 AM
gem module dont always replace
my problem was withy a short in driver door ajar switch had short cut wire to switch it stoped put new switch months later without switch when u close door exit truck with keys in pocket windows switch works left dog in truck went to bathroom in gas station dog opened window exited truck chased him for a half hour was a untrained puppy ford dealer wanted to replace my regular mecanic found the code
Old 05-05-2006, 04:16 PM
pitrow pitrow is offline
pitrow is starting off with a positive reputation.
Quote:
Geez, you might wanna try using punctuation next time. It makes it so much easier for your readers to try and figure out wtf you're trying to say.
Old 05-07-2006, 09:23 AM
Charlie Santi Charlie Santi is offline
Charlie Santi is starting off with a positive reputation.
I had to have the GEM and fuse panel replaced on my '98 not long after I bought it. The truck had some weird electric problems and the repair took care of they. The dealer did it a no charge, then sent parts to Ford. Never found out what was wrong.
Charlie
Old 02-02-2008, 03:37 PM
CACHO23 CACHO23 is offline
CACHO23 is starting off with a positive reputation.
HELLO,
I want to see pictures about de GEM, for the history problems mentioned by other fiends Im thinking that i need to get one.. please somebody show me the electrial part. thanks
Old 02-02-2008, 03:43 PM
my truck is a 1997 4x4, and the interior lamps not turn off always its on and the door ajar lamp in the dash goes on too.
Old 02-05-2008, 09:33 AM
leunhenr leunhenr is offline
leunhenr is starting off with a positive reputation.
I have a Ford F-150 and I had a leaky windshield a while back, and the dealer said I needed to have the GEM module replaced. I've already taken the old GEM out to look at it and put it back in, so I know how to replace it. But if I buy a new GEM module, does it need to be programmed by the Ford dealer before it can be used? I would hate to take the truck to Ford for them to replace the GEM because they charge an arm and a leg for it, while it's so easy if I just replaced it myself.
Old 02-05-2008, 10:09 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
You guys might want to start new threads about your problems rather than posting in this old one.
Old 02-05-2008, 07:45 PM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
Quote:
Spray some WD 40 in your door latches, this should fix your problem. this is a common occurance with these vehicles.
Gem module Wrecking ball 1999 - 2003 7.3L Power Stroke Diesel 11 06-27-2016 07:52 PM
GEM Module mrfixit5 1999 to 2016 Super Duty 0 04-07-2016 10:24 AM
Gem module Glenn Fisher 1999 to 2016 Super Duty 3 03-30-2016 12:59 AM
GEM module failure ? Jason Lilly Modular V10 (6.8l) 0 01-19-2016 11:02 AM
99 F250 superduty 7.3 diesel gem module or other problems petersonjustin55 1999 to 2016 Super Duty 0 08-03-2014 09:00 PM
Tags
1997, 2003, 2004, 97, expedition, f150, ford, fored, gem, gemford, location, module, moukle, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
