1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
GEM module
Old 02-12-2008, 04:07 PM
yosemitesamiam's Avatar
yosemitesamiam
yosemitesamiam is offline
Originally Posted by madsonp
Spray some WD 40 in your door latches, this should fix your problem. this is a common occurance with these vehicles.
WTF? I know the GEM controls the interior lights...and a host of other crapola it really shouldn't...like my random ABS light that turns off my auto4x4. :\
I'm going to go give this a go...
Old 02-13-2008, 11:09 AM
buzzard's Avatar
buzzard
buzzard is offline
Originally Posted by leunhenr
I have a Ford F-150 and I had a leaky windshield a while back, and the dealer said I needed to have the GEM module replaced. I've already taken the old GEM out to look at it and put it back in, so I know how to replace it. But if I buy a new GEM module, does it need to be programmed by the Ford dealer before it can be used? I would hate to take the truck to Ford for them to replace the GEM because they charge an arm and a leg for it, while it's so easy if I just replaced it myself.
Prior to removal of the module, it is necessary to upload module configuration information to scan tool. This information needs to be downloaded into the new module once installed.
Old 11-19-2008, 05:44 PM
rocco correale's Avatar
rocco correale
rocco correale is offline
free at the dealership????
Originally Posted by Charlie Santi
I had to have the GEM and fuse panel replaced on my '98 not long after I bought it. The truck had some weird electric problems and the repair took care of they. The dealer did it a no charge, then sent parts to Ford. Never found out what was wrong.
Charlie
are you kidding...? free at the dealership...?
Old 01-07-2009, 12:44 AM
yookie413's Avatar
yookie413
yookie413 is offline
As I've posted about the same leaking issue madsonp really knows his s*** so thanks so much however I do wonder if this is obviously such a big not to mention pain in the a^^ problem how can we contact ford and possibly have this looked at as a possible RECALL issue has anyone thought of this if so what was the outcome or are you still thinking? if enough of nus complain maybe we'll see results.
Old 01-07-2009, 12:53 PM
kailor's Avatar
kailor
kailor is offline
It happened to me and my 2000. $800 at dealership. New GEM and windshield removed, resealed, and replaced.
Old 01-08-2009, 02:14 PM
TerryB99's Avatar
TerryB99
TerryB99 is offline
Originally Posted by Racerguy
The GEM is bolted to the back of the fuse box.
Sometimes though the fuse box gets water in it and causes the same problems too.
Don't know if it was water, but my 2000 Nav just had the fuse panel replaced today. The blower motor was stuck on when the key was off, draining my battery.
Old 10-15-2010, 11:07 AM
ob1dominguez's Avatar
ob1dominguez
ob1dominguez is offline
Originally Posted by CACHO23
HELLO,
I want to see pictures about de GEM, for the history problems mentioned by other fiends Im thinking that i need to get one.. please somebody show me the electrial part. thanks
did you ever get any pics of the gem module?
Old 10-15-2010, 01:21 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
Umm, it's called a warranty.
Old 12-13-2010, 04:23 PM
WorthCanoy's Avatar
WorthCanoy
WorthCanoy is offline
GEM?
I drive an 02 Expedition 4x4, and recently my running board lights and interior lights are not coming on when I click the "unlock" button.
Think that's the GEM module?
Dealer told me today the module is $512!!!
Old 04-19-2011, 08:52 PM
Home Brewer's Avatar
Home Brewer
Home Brewer is offline
What all exactly does this GEM module control? Lately my fuel gauge and door locks are acting up. Could this be something to look into?
Old 04-20-2011, 04:06 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
The GEM controls a whole host of stuff in our trucks; From running board lights to transfer case operation. There are about 40 or more functions that the GEM provides power for.
Old 12-28-2011, 12:02 PM
96max2fast's Avatar
96max2fast
96max2fast is offline
back from the dead...
I resealed my windshield but the GEM module still got wet somehow... any ideas?
  #28
Old 12-28-2011, 01:36 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Have you hosed down the truck and looked for water?
  #29
Old 12-28-2011, 01:55 PM
96max2fast's Avatar
96max2fast
Yes but can't tell...
  #30
Old 12-28-2011, 04:02 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
If the GEM got wet after it was dry and the windshield was resealed the reseal was not done properly. I think the only other possibility would be a sun roof drain leaking inside.
Quick Reply: GEM module
