V10 Surging at idle
V10 Surging at idle
Here's a wacky problem that started about 1000 miles ago. When warmed up at idle in 'drive', my 98 V10 E350 will surge as in engine cutting out and then catching itself and leaping ahead or just rocking like AC-DC is playing live in the back of the van.
I had a prior problem of the engine dying on heavy braking where the trans didn't seem to downshift fast enough-that's been 90% corrected.
I wonder if this is a common problem and what 'module' controls the idling. I'll try some FI cleaner but it feels more electrical than fuel delivery BUT could maybe be a fuel pump issue.
If I hld the idle just slightly higher off idle in drive at a stop-it vanishes...
Could be a couple things.. When you say dancing, is it more like a regular idle, and then drop down to about 350 and shutter, and back up to regular (repeatedly) accompanied by any dieing in Drive/Reverse? Does it die when wheels are fully turned left/right?
Has there been any check for vacuum leaks, cracked pcv, egr, egr tube?
Cleaned MAF, IAC or throttle body?
