f250 7.3 diesel CHIP HELP - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-22-2012, 10:02 AM
jshansen jshansen is offline
jshansen is starting off with a positive reputation.
sorry if this isnt in the right forum i just registed for this site. but anyway i bought a 1999 f250 7.3 diesel exteneded cab long box about 2 months ago. i finally have some money now and am considering doing some work. i am thinking about buying a chip. first off whats the difference between a chip, tuner, and a programmer. i want to get one for 2 reasons . a) blow black smoke an b) boost my fuel economy a little bit. currently i get around 13 or 14 in town. the reason i havent got one yet is my buddy says they mess up your truck. i no they can be hard on a transmission but i push snow so i already know im going to have to get a new tranny at some point. he was saying they hurt your engine and mess up for injectors. any truth to that? finally if they is a decent chip in the price range around 300 to 400 any suggestions. i was looking at the Superchips 1855. but i dont no if that any good or not. thanks in advance for your help
Old 02-22-2012, 10:52 AM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
You arent going to get very many friendly responses when you start your first post with " i want to blow black smoke"... but i know pretty much all the 7.3 guys run DP tuners
Old 02-22-2012, 11:23 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 02-22-2012, 11:33 AM
fuelman fuelman is offline
fuelman is gaining momentum as a positive member of FTE.
You can't get mileage and "black smoke" at the same time. As mentioned not many are real keen on the black smoke thing, it just brings a bad name to the diesel world. As for damaging the injectors not really true. About the only two things that damage injectors are bad fuel filtration and dirty oil. No one here will recommend a "superchimps tuner, so look at DPTuner, Power Hungry Performance or Elite Diesel. Those are the TOP three programmers for the 7.3l. As for your transmission the torque converter will suffer first. As for mileage you can get better mpg with a chip if you keep away from enjoying the increase in hp and torque, but mpg is mostly driving style.
Old 02-22-2012, 11:38 AM
overthehillbill's Avatar
overthehillbill overthehillbill is offline
overthehillbill is gaining momentum as a positive member of FTE.overthehillbill is gaining momentum as a positive member of FTE.
Don't even think about a chip til you get gauges.
Old 02-22-2012, 11:49 AM
01PS 01PS is offline
01PS is starting off with a positive reputation.
As recommended to another user I would suggest working ALL of the bugs out of your stock truck before getting a tuner. It's a PITA to remove the tuner every time you need to chase a gremlin you ignored 'cause you wanted to "go fast". X2 on the gauges first also. Black smoke = high EGTs = motor work if you don't watch it.
Old 02-22-2012, 12:39 PM
so pretty much buy gauages then get a DP tuner or chip. im still lost at what the difference bettween a tuner and a chip is
Old 02-22-2012, 01:08 PM
Tormz Tormz is offline
Tormz is starting off with a positive reputation.
What gauges besides boost Should Some one have
Old 02-22-2012, 01:15 PM
acf6's Avatar
Boost, EGT (exhaust gas temp), Trans temp
Old 02-22-2012, 10:48 PM
crop harvester crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
from what i understand a chip is a part that connects to your trucks sytem and a program is loaded through your data link connector, while storing your stock program in its memory. i like the chip idea so you dont have to stop and reprogram when changing, the chip can be changed on the fly.
Old 02-23-2012, 01:24 AM
1WildPig's Avatar
1WildPig 1WildPig is offline
1WildPig is starting off with a positive reputation.
I got my 6 position PHP Phoenix chip from Kenny at KT Performance (.net) for $295 + Shipping. If you decide to go with Kenny, you can email with him or talk to him on the phone to discuss your needs and wants...real nice guy to do business with....
By what I gather, the stock injectors will support an extra 100 HP and you can get higher HP settings but the injectors can't really make as efficient use of the fuel and this is where you'll get smoke from...not really good for anything but putting on a show...but, if that is what you want, tell whomever you decide to order from (they'll need the number off your PCM too) and they can recommend a setting....as I'm sure some on here that already have a Phoenix type chip can as well...
With the type of chip I have there are 6 positions that you can fill - you should discuss how you use your truck with whomever you are ordering from to get the most benefit from your choices...other choices of chips can have many more positions....more money will get you more choices...
My particular needs are met with the following settings; Stock, Whisper, 80 HP Daily Driver (used most of the time), 100 HP Performance (not really needed but it will let it roll), 65 HP Tow, and Anti Theft ... If I had to do it over, I might would get a higher idle setting instead of the 100 HP...but, if I can find a good deal on a auxiliary power control module (idle controller) that'll take care of it...
Luck to ya..
Old 02-23-2012, 02:27 AM
Whisper setting? What does that do
Old 02-23-2012, 03:32 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Quote:
Tuner is the person doing the tuning to the on performance chips or programmers
DP Tuner is still a chip although it is not a TS style chip like nearly every other tuner uses.
Chip is what a TS style, DP Tuner or other manufacturer use to write the performance programming on. You install it on the PCM(Powertrain Control Module AKA Computer) and have an option of "switch on the fly" changes.
Programmer is usually either a handheld device, ie superchips, diablo predator, etc., or an inclusive device that is mounted in the cab to also allow monitor of certain gauge features and some have the ability to pull diagnostic codes.
Quote:
Quiets down the motor, DP tuner calls it Drive-thru tune. Idea is to keep from turning off the truck at Teller lanes and Drive-thrus
Old 02-23-2012, 06:02 AM
roostercrows's Avatar
roostercrows roostercrows is offline
roostercrows is gaining momentum as a positive member of FTE.roostercrows is gaining momentum as a positive member of FTE.
Welcome to FTE!!
Chips and programers are a hotly debated subject and some get pretty excited over the matter.
In any case you should start with gauges and tunes that are built for your truck.
There are a few that are heavily supported by many on this forum and all have good results. Do lots of reading and pick the company that you feel the most comfortable with.
Old 02-23-2012, 07:23 AM
tommyl tommyl is offline
tommyl is gaining momentum as a positive member of FTE.
You probably need a bigger trans. cooler, if it hasn't already been upgraded.
TS performance 6 chip Leemakesmepee 1994.5 - 1997 7.3L Power Stroke Diesel 23 09-05-2011 11:27 AM
EGT Probe Install 2cylguy 1999 - 2003 7.3L Power Stroke Diesel 4 06-25-2011 07:47 PM
Questions about a chip (2011 F-150 5.0L) 640 CI Aluminum FORD Computer Chips & Tuners 1 04-23-2011 05:55 AM
Chip questions mikeismadness 1994.5 - 1997 7.3L Power Stroke Diesel 11 03-02-2011 02:42 AM
Diagnosing an F250 7.3 diesel dusred 1999 - 2003 7.3L Power Stroke Diesel 21 08-21-2008 11:17 AM
Tags
1997, 2005, 250, 73, chip, chips, diesel, edge, f250, ford, high, inline, realy, superchip, temp, trans, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
