Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 02-22-2012, 08:45 AM
slickmainer's Avatar
slickmainer slickmainer is offline
1965 Ford F-100
My Garage
slickmainer is starting off with a positive reputation.
Unibody cab mounts
I picked these NOS mounts up off ebay
I don't think they are repoped but I took some measurements and made this if it helps someone
I don't have any measurements for the bottom but they are just squares
Gregg
Maine
  #2 (permalink)
Old 02-22-2012, 09:31 AM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
The Model 66 uses the same front mount set as a model 81 It is the rear mounts and back where they are different.
Garbz
__________________
64 F100 "Christine" heartless and mean
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive 302 C6
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #3 (permalink)
Old 02-22-2012, 01:23 PM
1965 Ford F-100
My Garage
oops, so is there a source for the rear mounts for the uni?
the ones listed are the front ones right?
  #4 (permalink)
Old 02-22-2012, 04:13 PM
garbz2's Avatar
1963 Ford F-100
No such thing as rear mounts.
The back of the cab sits on the frame.
The rest of the bed does the same on oak blocking inserted in the cross members.
Above and under the frame a 1/4" thick 2x2 reinforced rubber square is used. (looks like a tire without tread)
Garbz
__________________
  #5 (permalink)
Old 02-23-2012, 11:43 AM
1965 Ford F-100
My Garage
thanks Dave.
Tags
1961, 1963, 96, body, cab, escape, f100, ford, frame, front, hybrid, mounts, taurus, truck, unibody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
