I thought the only difference was the offset/backspacing? I put 2010 rims on my 2001, they fit the lug pattern but the front wheels rubbed real bad. I had a 2k foot turning radius...
Yes, it’s called a power drill and a large drill bit but I would not recommend it. If the bolt patterns don’t match up then you have two choices, different wheels or converting your entire system over to match a 2007 configuration. Cheaper to just find a different wheel…
I just tried tirerack.com wheel fitment...it says 2001 F350 dually 4x4 has 8-170 and 2007 F350 4x4 has 8 - 200. I could very well be wrong, it wouldn't be the first time and I know not the last.
